Thread: silverado vs jeep cherokee
Page 1 of 12 12311 ... LastLast
Results 1 to 20 of 227
    Registered User southcarolina12's Avatar
    Jul 2011
    south carolina
    who would win stock for stock in a drag race? 2000 silverado with a 5.3 vs a 1998 jeep cherokee with the 4.0L inline 6.
    2000 silverado z71, 315 mud grapplers, leveled, k&n intake, flowmaster 40, cat delete, hid, strobes, bully dog tuner, msd ignition, e3 spark plugs, polished throttle body, shift kit, long tubes, z06 cam
    Are we there yet?! PETTERLE's Avatar
    Dec 2009
    bay area cali
    Re: silverado vs jeep cherokee
    my old 2.2 s-10 with 4.10 gears would toy with those heeps all day long, i think you'll be alright man.....
    -Josh-
    1999 S-10 3/4 drop, K&N intake, borla muffler, zq8's, 20 mpg
    1990 K2500LD 4" lift, 35" pro comps, almost driveable again!
    1988 K1500 4x4 4" lift 33" at's, a lil more motor. Want to set on fire. About to be sold.
    OBS Magicman 97NCZ71's Avatar
    May 2009
    Colerain, NC
    If my 5.7 will outrun one.....im pretty sure a 5.3 could as well.
    Just hammer down and hold it. Chances are the jeep owner will ***** out around 90 and let off.
    1993 Chevrolet Blazer, 261k, Turtle Bowl Injection, Titans, 3" catback.
    1997 Chevrolet Silverado Z71: Build Thread
    The way I see it, an OBS is like sex-when it's good it's terrific, and when it's bad it's still pretty good!
    A jest breaks no bones. BOTMAN's Avatar
    Jul 2008
    Norman, Oklahoma
    Quote Originally Posted by 97NCZ71 View Post
    Just hammer down and hold it. Chances are the jeep owner will ***** out around 30 and let off.
    Fixed your post.... :looking:
    Cape Cod, MA
    Having only known the Jeeps and their I-6 engines for more than half of my driving licensed life, I can tell you that I wouldn't even bother to waste the gas or the wear and tear on the truck. My Silverado feels like a Camaro compared to my old Jeeps and I thought those things scooted pretty well when the pedal was mashed to the floor. I now know that wasn't the case. Your truck will win and it should: modern 5.3 v8 versus a 1970's era I-6... not even a fair fight really.
    Nov 2011
    FL
    That's kind of a silly comparison. The I-6 doesn't make anywhere near the power, but it does make a reasonable amount of torque down low where a 4wd can use it. The 5.3 has much better fueling, it flows more air and makes much better high end power where a truck on the freeway can use it. The I-6 may win on longevity - they tend to run damn near forever. They also pull pretty hard at the low end, so don't be surprised if they get an edge coming off a light. They cannot hold it though, they run out of wind just over 3000 rpm, while the 5.3 just starts to wake up there.
    Ohio
    You guys do realize you are talking about the 4.0L I-6 with MPI that was not introduced until the late-70's, and this '98 would be an even more powerful H.O. version? This isn't the old 258 I-6 carb'd that the responses above seem to be talking about that were dogs with limited rpm range.
    The Jeep would have 190 HP (at almost 5,000 rpm) engine but only weighs between 3,000 and 3,500 lbs. In other words it would have a better horsepower to weight ratio than a 5.3L truck. I also did a quick search and found reports of similar 0-60 mph and 1/4 mile times between the two types of vehicles.
    Don't get me wrong as I'm not saying the Cherokee would win, just that I don't think it would quite the non-event that the responses make it out to be.
    Nov 2011
    FL
    Quote Originally Posted by grayblazer View Post
    Yep, I've had several of them and they don't breath well at the higher rpm ranges. The 4.0 came out in the '91 YJ, I think they were in the Cherokee a year or so earlier. They are torquey engines that are well suited to 4 wheeling, but they are low rpm engines. They don't breath as well as the 258's and a popular upgrade is to put the old head on the newer engine. Don't be too critical of carburetors - I have a carb'd 258 in a Jeep now that would run circles around the stock 4.0's I've had in the past.
    Again - I would expect the 4.0 to pull ahead on the short distance (assuming it is geared right), but the 5.3 would pass it by once the rpm's picked up.
    Lanark, Ontario
    I've driven quite a few 4.0L jeeps (nto 258 jeeps). The engine is torquey, but doesn't have much zip to it.
    Power to weight argument...
    190hp/3200lbs (4x4 XJ's range from 3050-3300lbs IIRC) = 0.059hp/lb
    285hp (2000 LM7 spec)/4667lbs (based on my registration) = 0.061hp/lb
    I know my L33 would eat it alive, having driven both.
    May 2009
    Colerain, NC
    I owned a 4.0 Cherokee as well, theyre peppy for what they are but definitely not speed demons. They're still awesome engines though, mine had 187k miles when i sold it and was still running strong.
    Ohio
    Meant to say "late 80's", not late 70's.
    Again, I'm saying the Cherokee would win but the power to weight ratio might be a little skewed above. I thought the 2000 models were still rated at only 270 HP and 4,600 lbs. seems pretty light for a lot of versions of this truck. I'm somewhat doubtful a 4x4 extended cab only weighs that much.
    May 2009
    Colerain, NC
    Honest truth.
    Its going to come down to who has the balls to lay it on the floor and hold it. The end. Case closed.
    Now....i have the urge to go look at pictures of my old cherokee :lol:
    Jul 2011
    south carolina
    thanks to all of the replies i beat him in my truck but he said if mine was stock then he would have won by a long shot so ima race him in my dads stock truck
    2500 6.0 vortec
    Dec 2007
    naples,FL
    Finally someone comes through with an actual race results. Usually they start a stupid thread like this and never come back with results.
    Jul 2011
    south carolina
    haha im not scared to race someone and im not scared to loose but i just like knowing what im getting into first. he had me at the take off by about 3 feet and then i flew by him after i hit 15-20mph and after that the gap just kept getting bigger and bigger.
    Registered User mindless's Avatar
    Nov 2006
    West Seneca NY
    My truck would eat my xj but it sits on 35s haha. But yea the 4.0s with stock tires move alright but wont hang with the 5.3s.
    2008 Silverado 5.3 Z71
    1996 Cherokee 5" lift 35s locked and loaded
    1992 Civic 500+ whp 10 second monster
    Oct 2010
    jacksonville florida
    its okay guys i attempted to race a 07 350z supercharged, lets say i was scooting along pretty good with my 4.56s and 31s but somehow just somehow he was behind me and i was going hard an fast as i could and he closed the gap in seconds....... :lol:
    4.8l, spectre CAI, Glasspacks, 5/2 lift, 3inch summit BL,
    4.56s on 265/70/17s :lol: 15mpg
    Jul 2011
    south carolina
    i raced a corvette one time and it was like i was sitting still.
    LM7 Outlawz2004's Avatar
    Louisiana
    race probably never happened.LOL just posted what he thought you guys wanted to hear.
    Jul 2011
    south carolina
    which race? me and the cherokee? yeah it did and i raced the vette at the beach this past summer just fu*king around.
