Thread: Bogs down.
Results 1 to 8 of 8
    Chevy Runs Deep kjk1500's Avatar
    Easton,Maryland
    Bogs down.
    My truck bogs down when I floor it after second gear and some times when I take off a little faster then usual. Is this the fuel building up in the throttle body and then taking off?
    1994 k1500 K&N cold air intake, TBI spacer, Edelbrock shortys, Straight pipe exhaust, Corvette Servo.
    Jan 2004
    Dixon IL
    Re: Bogs down.
    no codes right?
    Jan 2004
    Dixon IL
    Re: Bogs down.
    also, I think this week you asked about more power and a heat problems?
    are you sure you don't have a head gasket bad? or a cracked head?
    Easton,Maryland
    Re: Bogs down.
    How do I check codes? Or could it be from just simple bolt ons I have?
    Jan 2004
    Dixon IL
    Re: Bogs down.
    so you do have a check engine light on?
    Easton,Maryland
    Re: Bogs down.
    Yea I dont think its cracked or bad its not leaking oil down the sides of the block or anything. I do have a small oil leak at the back of the motor where the intake manifold is. I think its the crappy silicon gasket job on it.
    Jan 2004
    Dixon IL
    Re: Bogs down.
    you'll need to get a paper clip to pull them, I'm sure there is a big write up some where on this, I don't have time right now to type it all up....if you can't find anything, I'll type it up in an hour.
    check the antifreeze for oil and the oil for anti-freeze. after that, do a compression check.
    Easton,Maryland
    Re: Bogs down.
    Ok I just change both recently like this month and they were fine. The check engine light just started coming on but only when Im Ideling sometimes not every time though.
