Thread: Solid axle swap tahoe
Results 1 to 20 of 35
    Registered User c3ncalchevy's Avatar
    Jun 2009
    visalia
    Hey there, I'm stuck with this,
    I have a 99 chevy tahoe (obs) and I already did a solid axle swap on it with a chevy Dana 44, after all this I found out That I need a hp ford Dana 44 to get it 4wd again. Because I have the autotrac t case . What all I need to do or find when looking for a ford hp Dana 44 , I'm currently have stock 3:73 gear in both. Working on cross over steering. Would the flat top knuckle inter change with the chevy and ford Dana 44 ? So if I do this cross over steering so I can drive it for now then when I find the correct axle the steering would still work ?
    Thanks
    May 2010
    Deland, Fl
    Re: Solid axle swap tahoe
    you can do a np205 case with the vss adapter....
    '94 GMC C1500 RCLB, DD - Sold
    Registered User 03SMURF's Avatar
    Marion and Columbus, Oh
    The better route would be to find a p-drop 241. I can't remember the exact year, maybe around a 91 blazer/suburban. It should bolt up and already has vss. A little searching will tell ya exactly what you need.
    01 2500HD 8.1/Ally/D60HP/ORU ~13in/ Bils 5150's/39.5 Rockers/spooled rear, detroit front/5.13s/AEM/Magnaflow/PSC/Nelson tune and some more.
    05 F-350 SRW Lariat PSD - tow rig, AEM, straight piped with 6.4L tip.
    08 Honda Civic Mugen Si - Stock, DD.
    Registered User 891TON's Avatar
    Jul 2011
    durham ct
    if you take the Ford route the dimension you need to know is 28.5". Thats the center to center spring perch width. Its most commonly found in 78-79 ford f250s. It will be the Reverse rotation high pinion you are looking for. ORD makes a crossover steering kit that will make things very easy to bolt up with a drop pitman arm, steering arm and draglink.
    1989 Chevy K1500. solid axle swap with D60 front, 5.13 gears, powertrax lockright, 14 bolt FF rear, 5.13 gears, Detroit locker, 5.7L TBI, 40" BOGGERS, 16,500LB superwinch.
    Quote Originally Posted by 891TON View Post
    center to center is 31.5"
    Jun 2009
    visalia
    Once I find a p-side drop 241 it bolts up to my 4l60e and I ditch my old electronic shift t case , do I need to get an adapter? Thanks for the help
    Quote Originally Posted by c3ncalchevy View Post
    Here is a good write up on a driver drop 241 swap. Physically the two should bolt up the same, make sure you get a tc with a 27 spline input to match your 4L60E. I don't know for sure if the wiring between the driver and passenger drop is the same. Study up on this thread so you can ask more specific questions when the time comes and more knowledgeable members will help.
    http://www.fullsizechevy.com/forum/g...p-writeup.html
    Jan 2005
    northern KY
    90-91 blazer and burbs had a p-drop 241 with the Vss. should be exactly what you need
    '89 K5 trail rig
    Registered User mainechev's Avatar
    Jun 2010
    The Woods
    Thanks
    Not trying to be a dick, but I have to wonder, how did you go through all the work of swapping in a solid front axle and not notice that you'd need a drivers side pinion? The front output on the stock t-case is clearly oriented on the drivers side.
    Again, not trying to be an jerk, just curious.
    98 Chevy RCLB K1500, 5.7, 4L60E transgo shift kit, vette servo, 14 Bolt SF, 3.73s, Blackbear 89 tune
    Jun 2009
    visalia
    Quote Originally Posted by mainechev View Post
    I know stupid, I looked more into doing the sas suspension part and was thinking there was and easier way with the t case ( knowing my front drive shaft was on the d-side) could buy a adapter or another t case but found out it's more then that, this chevy dana44 was given to me and sat in my garage for a bit before I thought of doing the sas. But now I'm here with a sas tahoe with a chevy Dana44 , I set the tahoe aside for a year now because stuff came up and I been driving my jeep but I want to finish this project.
    That is my chevy tahoe and my buddy 90 chevy single cab.
    StIcK iT uP uR pOoPeR! big99chevyZ71's Avatar
    Sublette IL
    nice, you have more pics of both trucks?
    SAS 60/14 bolt 5:13 gears sky-kit 6'' springs..38'' mtz
    Jun 2009
    visalia
    Quote Originally Posted by big99chevyZ71 View Post
    I did but I don't know what happen to the the others.
    Registered User rabbiporkchop's Avatar
    Jun 2011
    NEPA
    The cheapest route would be to use a Transfer case out of an 88-91 k5 or suburban, then you can use a front axle out of the same vehicle. Otherwise you could put in a driver drop manual shift t-case and use a 77.5-79 f250-f350 front axle, which is how mine was built.
    Jun 2011
    NEPA
    Thanks
    Keep your Chevy axle and just put in an 88-91 Transfer case out of a k5 Blazer or a suburban.
    Jun 2011
    NEPA
    Thanks
    Jun 2009
    visalia
    Quote Originally Posted by rabbiporkchop View Post
    What do you have? Do you have picture of your set up and ride
    Thanks
    Jun 2011
    NEPA
    I have a 95 Tahoe sas with a 79 f250 high pinion Dana 44.
    Here is the D60 rear with disc and e-brake.
    Need to be bigger!!!!!!! speedjunkie's Avatar
    Feb 2002
    Pittsburgh PA
    Nice black tahoe. Let me guess, one off sliders?
    Damian
    2011 GMC CC 4x4 6.2 black
    1998 Chevy ECSB 4x4 black full Throttle on 38s, traded.
    Jun 2011
    NEPA
    one of a kind. (I hope anyway)
    Jul 2011
    durham ct
    whats the matter with me? sorry thanks for catching that. Its actually more like 32.5" IDK what I was thinking.
