Thread: Engine performance gain
Results 1 to 11 of 11
    Jan 2012
    Muskogee, OK
    How much HP am I looking at when I put vortec heads, edl performer Rpm, lunati 262/268 over stock?
    Sep 2003
    Catalina, AZ/Swartz Creek, MI
    Re: Engine performance gain
    No idea...
    What are you putting it on?
    What is the stock HP rating of whatever you're putting it on?
    What vehicle?
    What gearing?
    What trans?
    What size tires?
    Roundabout guess on the combination you listed is probably 325-345hp on a 350 depending on compression ratio.
    Registered User Rally Smith's Avatar
    Sep 2008
    Montana
    What gearing?
    What trans?
    What size tires?
    Non of these factors have any bearing on how much HP the engine will make.
    Sep 2003
    Nope.
    It will allow an informed decision to be made. If you throw an engine with a 2,500-6,500 powerband into a 5,000lb. truck with a 3.42 rear, stock stall converter, and 35" tires it will be an absolute dog everywhere you go, granted the cam isn't very big.
    Sep 2008
    Montana
    Doesn't answer his question though. He wanted to know the power question, not the best performance question.
    Jul 2010
    USA
    Regardless, the OP has not provided nearly enough information to intelligently answer his question with any such reply containing merit, "Mr. Smith". This is the point Doober was trying to illustrate, that the OP should provide more information if he wants help with this matter.
    '96 K1500 SUBURBAN
    Sep 2003
    If nobody mentions it he may never know. Based off the information he gave he was given more or less the same amount of info back. He didn't specify if it was a '67 pickup with a 283, a '75 with a 400, a '95 with a 305, etc... there's no way of knowing WHAT he has so the only thing one can do is ASSume and make an educated guess at what he may have.
    *DERP*
    I can only type so fast on my phone.
    May 2006
    Alberta Canada
    not a expert on cams but that one looks huge..not something ld want in a daily driver...may be vacum issues(brake issues)..if that cam is as big as l think it is may wana add a aftermarket elec vacum pump....most here are running cams around the 207-234 range,,that cam you have would be something ld expect to see on a drag car ect im thinkin..then of course if thats what your buildin go for it
    [Stole/FOUND 13/03/08 :O)
    70 fury 3
    71 sport fury GT
    Sep 2003
    It's he advertised duration, not the .050" figures. If it's the cam I'm thinking it should make for a decent running engine, just need to make sure the rest of the drivetrain is set up properly.
    http://www.summitracing.com/parts/LUN-60102
    That's the only SBC Lunati cam with a 262/268 duration.
    Jan 2012
    Muskogee, OK
    It's in a c1500 shortbed, with stock flat top pistons, 3.42 posi rear end. 22's are the wheels, automatic th400.
    Jan 2012
    Muskogee, OK
    350 v8.
