Thread: 1995 K1500 Loud Ticking After Exhaust Manifold Replacement
Results 1 to 19 of 19
    Mar 2012
    OC/IE, CA
    Hey everyone, I'm new here and I decided to register as I now own a '95 K1500 Z71 and found this forum extremely helpful thus far. Anyways, my dad and I replaced the left (driver side) exhaust manifold and now there is an EXTREMELY loud ticking noise coming from the left side when I give the truck any gas. We also noticed that when we took the old manifold off there was no gasket on it, which we replaced with gaskets provided with the Dorman manifold.
    My question is this: What is causing this extremely loud ticking noise when I give the truck any gas? Did we position the gasket incorrectly when we put the new manifold on? Is a spark plug perhaps loose?
    I apologize if this subject has been beaten to death. I did try to search but did not find anything relating to my exact issue.
    Any help is much, much appreciated.
    Oct 2011
    Ontario, Canada
    Re: 1995 K1500 Loud Ticking After Exhaust Manifold Replacement
    It probably took you longer to post this question than it would have to check the spark plugs.
    If this randomly happened while driving to someone who never pops the hood. We can throw alot of guesses at your problem but since you managed a manifold replacement. You are obviously comfortable under you hood.
    You have an exhaust leak. Even the manifold to exhaust can have a ticking sound. Torque the bolts again and listen for a change ticking sound.
    Mar 2012
    OC/IE, CA
    It's a little too late to get under the hood and I was throwing ideas out for clarification on what my potential problem might be.
    So you're saying to retorque the bolts on the manifold, right? I went back and checked all of the bolts on the manifold and where the "donut" gasket is and none of them are loose, which is why I am puzzled.
    Jul 2010
    Mora, Minnesota
    If they seem tight check the plugs. Also how did you tighten the manifolds? just a ratchet or torque wrench
    Current Ride
    2004 Chevrolet Silverado 2500HD 4x4 6.0L
    Past Rides
    1997 K1500 ECSB Z71 5.7L 350 Vortec
    1994 K1500 ECSB Z71 5.7L 350
    1992 C1500 ECLB 5.7L
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
    Aug 2011
    WV
    You have a leak somewhere. Put a straight edge across the manifold and make sure it's straight and do the same on the head. You should see black where it's leaking if its that bad. These are for headers but will seal unless something is warped real bad. http://www.summitracing.com/parts/PHP-66121/
    May 2006
    Alberta Canada
    would say leak around headers or collectors...tappets realy sound up when theres a leak
    [Stole/FOUND 13/03/08 :O)
    70 fury 3
    71 sport fury GT
    Mar 2012
    OC/IE, CA
    Quote Originally Posted by 1997chevydriver View Post
    I tightened them with a ratchet at first so the manifold would hold and then went back to snug them with a torque wrench. I checked again today and none of them were loose.
    Bowtie44s - I will try that tomorrow morning. Would you recommend I use those header gaskets that you posted instead of the gaskets that came with the Dorman manifold? If so, do you know of any similar quality gaskets that I could pick up at, say, O'Reilly or Autozone?
    Registered User GirchyGirchy's Avatar
    Aug 2011
    Central IN
    Quote Originally Posted by bowtie44s View Post
    Do this - had this happen on an aftermarket exhaust header for my Nissan Altima. There was an obvious low spot in the flange where it mounts to the head.
    Aug 2011
    WV
    Quote Originally Posted by TheOutsider View Post
    My autozone has them for a 350. If there is a slight imperfection those gaskets will seal a lot better, they are thicker, like 3 layers and softer. I would check to see if there is a bur or something behind them holding them up and the straight edge check. Manifolds rarely leak. Make sure it is leaking there. A leak as loud as you described should be easy to feel with your hand at idle.
    Mar 2011
    Ronan Montana
    Did you replace the donut, too? I would do the donuts on both sides if you find out it's leaking on your ticking side. Mine was - it's tough to see or feel but I found it to be the source of the ticking. It was most obvious at first start-up + when I stomped on it in gear. The best way in my opinion is to drop the exhaust off the hangers so it is free floating (close to the installed position as possible) - replace donuts with new bolts/hardware and re-hang the exhaust.
    Jul 2010
    Cleveland
    I just did this on my 95 as well. Things I can think of:
    -Bad manifold. Was it used, aftermarket? They needed to be check for flatness before installing. My used ones were extremely warped and managed to score some almost NOS GM ones.
    -Gasket. GM did not use a gasket from the factory. My new bolts loosened up last week allowing the gasket to slide up (i had the gaskets with hooks). I'm wondering if I should've not used them now.
    - Donut gasket to pipe. These crush on installation and must be replaced. I had lots of trouble getting mine to seal up right, with the springs on the bolts it only applies so much pressure to crush these gaskets. My y pipe was not a perfect fit and I had to add some washers to get it to seal.
    You can use a piece of hose (fuel line etc.) in your hear to listen around and pinpoint the leak.
    Mar 2012
    OC/IE, CA
    Bowtie44s - This may seem like a stupid question: Do you even need to install a gasket for the exhaust manifold? The reason I ask is because after I took the left (driver side) exhaust manifold off there was no gasket and it seems that this loud ticking noise began AFTER I installed a gasket on the manifold. I thought you always had to install a gasket between the block and the exhaust manifold, however, as I previously stated, there was no gasket on the old manifold I removed. The gaskets that came with the Dorman manifold seemed flimsy, so perhaps I should buy a better set of gaskets.
    Montana3/4ton - I did replace the "donut" gasket when I replaced the left (driver side) manifold. I have the manifold for the right side, but I just haven't had the time to install it. I even went back, unbolted everything, checked the "donut" gasket, and then retightened the three bolts where the gasket is.
    Jayrodoh - The manifold is a brand new Dorman. I used the gaskets that came with the Dorman manifold, which also had "hooks" like the ones you described. Should I pick up some hook-less gaskets or buy some better quality gaskets with the "hooks"? As for the "donut" gasket, I also replaced that with a brand new one that came with the manifold. I even went back, unbolted the three bolts, took the "donut" out, reinstalled the "donut" and then bolted everything back together.
    Jul 2010
    Cleveland
    I would've still checked it for flatness, some of the aftermarket stuff isn't of too high quality these days. I think i'd take a resurfaced GM one over a new aftermarket one.
    Since you have the hook style, you can easily loosen the bolts and pull those gaskets out and try without them.
    I'd still determine where exactly it is leaking first though.
    Aug 2011
    WV
    Someone else said gm didn't use gaskets. Maybe you're ahead not to. I really only mess with headers. I have taken off manifolds and they had gaskets but i've never installed manifolds. You could try it without and see but if you do need gaskets i highly recommend those aluminum ones. I have also heard to just use a bead of ultra high temp copper rtv and that is the best you can get. Once again, all my information is for headers.
    Mar 2012
    OC/IE, CA
    Jayrodoh - If I absolutely have to I will take everything off again and double check to make sure the manifold is flat. I'm pretty sure it was when I was examining and comparing it to the old one, but mistakes do happen. As far as removing the gaskets, can I simply loosen the bolts on the manifold itself or do I have to go through the pain of removing the power steering pulley again to get that damn bracket out of the way?
    Bowtie44s - I understand what you're saying. My plan was to remove the gasket and then check for noise and if it persists, buy another gasket and see if that solves the problem. I'll see if I have time today to get under the hood and then I'll post an update regarding the situation.
    Jul 2010
    Cleveland
    Yes that left one is a total PIA to do, I have it down to a science as I initially reinstalled my warped ones with gaskets and it didn't solve my problem. Once you do it a few times you get it down.
    You can just loosen the bolts and pull them out, I just reseated one of my gaskets last night as the bolts loosened and it blew out.
    I would seriously get a piece of hose and probe around before you go and start removing thigs etc.
    Dec 2007
    orlando
    2- things you need to do. 1- put a gasket on the manifold. You can buy them at autozone. They are 3 or 4 gaskets on one side. 2-put permatex ultra gold copper on the donut gasket and tighten. Wait a day and let dry then run the truck.
    Mar 2012
    OC/IE, CA
    I loosened the manifold yesterday and removed the gasket that I installed with the new Dorman manifold. Started it up and no more ticking. I opened the box that is holding my other brand new manifold and noticed a small slip of paper that states, "FOR OPTIMUM SEALING... THE VEHICLE MANUFACTURER RECOMMENDS NOT USING A HEAD-TO-MANIFOLD GASKET FOR THIS APPLICATION." What the hell is that about? I cross-referenced the information provided on the slip with the information in a Haynes repair manual I have and the repair manual states a gasket should be installed with the exhaust manifold. I don't understand why there is so much conflicting information regarding whether to install a gasket or not.
    Registered User Botan's Avatar
    Nov 2011
    rhode island
    o.o i have a gasket on my 97 and when i did my headgaskets it still had a factory manifold gasket on it. wtf would you not need a gasket? do you have a CNG 350?
    My name is Lauren
    1997 C1500 Silverado.
    350 bored .060 to 6.0L
    4l60e with shift kit
    hypertech programmer
    75mm throttle body
    4" spindle lift, 2" block lift, 3" body lift
    31x10.50x15 = looks too small. needs 35's
