Thread: Blower motor blowing har but barely coming out of vents??
Results 1 to 20 of 23
    Mar 2012
    salem nh
    As it says in the title the blower motor is spinning on the highest setting but itonly comes out of the vents like its on low to medium. Any ideas???
    Registered User stocksilverado's Avatar
    Jul 2006
    colorado
    Re: Blower motor blowing har but barely coming out of vents??
    check under your dash for disconnected hoses and or lines . i had the same issue and a hose was undone.hope this helps
    Jan 2007
    Nebraska
    what vehicle? cabin air filter could be plugged
    Mar 2012
    salem nh
    a 1997 chevy k1500 i dont think there is one though....could be wrong
    Jul 2010
    Mora, Minnesota
    No cabin air filter.
    Your ac condenser may be plugged up with debris. Take your blower motor out and reach your hand in there up and to the left and feel around. Mine was plugged with pine needles and busted up leaves
    Sent from my SPH-M820-BST using Tapatalk 2
    Current Ride
    2004 Chevrolet Silverado 2500HD 4x4 6.0L
    Past Rides
    1997 K1500 ECSB Z71 5.7L 350 Vortec
    1994 K1500 ECSB Z71 5.7L 350
    1992 C1500 ECLB 5.7L
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
    Jan 2011
    Greenville, SC
    ^^^Yep that and feel around for leaking air from the plenum under the dash. I came across one that had the tube from the blower motor disconnected and much of the air was being blown out of there. Also check to see if there is any air coming from the defroster or floor indicating either a faulty blend door motor or a stuck blend door. Worst case, and I just did one of these, is the actual blend door seals are trashed and need to be replaced. This involved dash and plenum removal and doors replaced.
    1992 Sierra 1500 2WD 5.7L
    2000 Tahoe Limited
    1999 Tahoe Limited
    The Mustang Man
    Jul 2011
    Jawja
    Mar 2012
    salem nh
    Quote Originally Posted by rmodel65 View Post
    And where would the blend door be located??
    Jan 2011
    Greenville, SC
    They are inside the the big black box behind the dash. If you look under there just to the right of the gas pedal there is a blend door motor connected to spring loaded arms. You can try removing the motor (3 - 7/32nd screws) and turning the shaft manually. You will notice the differenct positions of that shaft determine defrost, vent, or floor selection.
    2000 Tahoe Limited
    1999 Tahoe Limited
    Jan 2007
    Nebraska
    [QUOTE=1997chevydriver;5577421]No cabin air filter.
    Sent from my SPH-M820-BST using Tapatalk 2[/QUOTE
    think you meant evaporator
    and I'd bet its an actuator/door messed up, is the air coming out of the defrost/floor?
    Jul 2010
    Mora, Minnesota
    Ooops..... whatever the one is called inside the truck, I always get them mixed up
    Current Ride
    Past Rides
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
    Mar 2012
    salem nh
    Yes always
    Jan 2007
    Nebraska
    if the air is always going through the defrost you have a mode/air door and/or actuator problem
    Burbanator riveeri1's Avatar
    Apr 2012
    El Paso, TX
    it nice i caught this. Would the controller be the problem as well. My truck does the same,
    Jul 2010
    Mora, Minnesota
    Possible but not as likely as the actuator motor
    Current Ride
    Past Rides
    1978 C10 RCSB 5.7L
    1969 C10 RCLB 5.7L
    Aug 2011
    WV
    It could be a mouse nest. The like to shred the carpet padding and insulation and put it in the heater vents.
    Jeff
    '88 Chevy K3500, aluminum head roller cam 511in³ stroker 10.5:1 compression, 96 NV 4500, 94-98 grille, 305/70-16 (33x12) BF Goodrich KM2s, 91 cluster swap
    Mar 2012
    salem nh
    Alright so I took the blower motor out and there was a little bit of debris but not horrible so I sucked it out with a vac.... All clear. I checked all the actuators and they are all spinning freely as designed. I'm at a loss here what would be the next step?? How do I check the actual doors and how do I get to them??
    Jan 2011
    Greenville, SC
    See post #9.
    2000 Tahoe Limited
    1999 Tahoe Limited
    Mar 2012
    salem nh
    Quote Originally Posted by Mr_Shamrock View Post
    See post #9.
    Alright I got that doors seem to be operating as they should as well in all positions... This is really frustrating it still seems to be not blowing fully in any position and it still seems to not go to any dedicated position even though I physically swing the doors move. What else can I look for that would cause this? Something else clogged? Maybe one of the vent hoses??
    Jan 2011
    Greenville, SC
    Your saying you removed the blend door that controls where the air blows and still don't have air flow? If so, either you have a major leak in the air plenum somewhere (just move your hand around the box feeling for a leak) or your evaporator is clogged. As long as your blower motor is working there isn't anywhere else for the air to go. If the evaporator is clogged I have removed the cover for the heater core before and just moved the heater core out of the way then used some degreaser, compressed air, and a small brush to gently get the crap out of it. Key work id gently - you don't want to bend the fins.
    2000 Tahoe Limited
    1999 Tahoe Limited
