Thread: 2001 HD Allison performance valve body replacement advice
Results 1 to 4 of 4
    Metalologist Chop Top's Avatar
    Jul 2004
    Texas 77971
    Awhile back I had some GM service done on my 2001 Chevy Duramax Allison automatic transmission. The shift points were slamming from 1-2 and 2-3 due to blowby in the throttle valves. The tech told me that aeventually I would need to consider an entire valve body swap if it gets bad enough. It's wearing out bad @ 220K on the ode.
    Well, a year later and it's now bad enough to address. I have lost accurate shifting capability form 2-3 and 3-4 for passing and pulling. I mean the truck does fine, it's just slow and with no pressures between shifting due to massive blowby. If I make it another year pulling the camper I'll be happy so I'm hedging funds for some major service again. I want to go hunting in Colorado, and the mountains will be brutal if I try to travel long distances with it like this.
    I need help and/or advice on the following:
    1) What good brands would I need to look at for a total TB swap.
    2) How hard of a job to do myself -vs- having my mechanic do it ? I know my way around an automatic transmission if it's a simple plug and play. If there is tuning and reflashing involved then I'm lost.
    Here is one I found while googling around. Or is this even what I need ?
    http://www.thoroughbreddiesel.com/su...valve-body.htm
    My thought process is that for what GM wants for the factory replacement I can enhance the truck's performance with an aftermarket part for the same money (about a grand).
    Not only would CT destroy his soul with demeaning and hurtful words in concise sentences, he'd sick a goddamn badger on him, then post about it on FSC.
    My build thread here:
    http://www.fullsizechevy.com/showthr...til-complete**
    EFI Live
    Jan 2008
    Wolfpack Country
    Re: 2001 HD Allison performance valve body replacement advice
    with that many miles and the shifts slipping and burning the clutches as bad as it is i would be looking into a full rebuild/built transmission. such as a suncoast stage III or something similar and would only be a few hundred more(than a grand)
    -Alex
    Thanks to:
    Dustin @ Diesel Addiction
    Rick @ Pro Fab Performance
    John @ Kennedy Diesel
    Jul 2004
    Texas 77971
    I was told the replacement trannies are like 6K. Am I wrong ? And if so then what can I expect to spend on a good rebuilt auto for my model ? I just put 1500 in a new transfer case last year.
    I want this truck to last. The engine is unstoppable but the tranny is getting tired.
    Registered User Jmac72's Avatar
    Feb 2012
    Humboldt IL.
    I would just get yours rebuilt.Around here a stock rebuild is about $3k a suncoast V is about $5k.If you buy another the core charge is $800 or so.
    03 2500HD duramax/allision,efilive,ad165,4"turbo back,etc
    95 3500HD 454/5spd century wrecker
    89 gmc 1500 350/auto,sb/stepside
    87 camaro z28 mostly stock
    72 camaro rs/ss 396/th400 looks stock
