Thread: 1995 chevy sliverrado 5.7 350 tbi problem
Results 1 to 19 of 19
    Jun 2012
    california
    Hello guys having some problems with my 1995 chevy. I drove my truck on sunday and went out on monday to drive it and it wont run. I am getting fuel spark . I can dump some fuel down the tbi and truck will run fine until i shut it off i cant get it to start . Is there anything i should look for . I also just replaced the fuel pump also . I just need help
    Mar 2011
    A, A
    Re: 1995 chevy sliverrado 5.7 350 tbi problem
    check fuel relay on left side of fire wall when standing in front of the vehicle. sounds like your not getting a prime.
    Jun 2012
    california
    should i click or make a sound to prime the truck . thanks for the help
    Mar 2011
    A, A
    do me something. have someone in you truck with the key off. you- lay under truck with ear close or on the bottom of the fuel tank. have a friend turn the key to the on position. not turning it on. do you hear the fuel pump kick on for a few seconds? yes= not fuel pump relay. no= next step
    if it does not prime. start your truck like you mentioned befor. just a little starter fluid works great. if the truck stays running go back to the tank and check for fuel pump operation. if fuel pump does work then it leads me to beleive the relay on the fire wall is bad. replace and check for operation again. if the fuel pump is not working or the truck does not stay running. pull a fuel line off the back of the tbi unit and turn the key on does fuel come out. if so its not the fuel pump.
    note. the pump should turn on for 2-5 seconds when key is cycled on. hope this helps.
    1993 C1500 5.7 4L60E Shorty headers, Voodoo Cam. Custom Tune.
    "Forever Be Strong" {R.I.P Cody Tavenier Brother & Friend 10/20/92 - 09/08/2009 Cancer Sux}
    Jun 2012
    california
    the truck will run when i add starter fluid and keep running till i shut it down and then i try to start it again and thats what happens i dont get the prime and i think its the relay
    Mar 2011
    A, A
    ya if your not getting fuel pumo prime when you cycle the key on. its going to be a relay.
    good luck hope it helps
    Jun 2012
    california
    ok ill get a relay after i put my kids down for there nap thanks ill get back to you on the issue to see if it helped me
    Jun 2012
    california
    i went and bought a new relay and its doing the same thing cranks over and nothing
    Jun 2012
    california
    so i dump some fuel down the tbi again and its running fine any clues
    Mar 2011
    A, A
    check power at relay. see if there is constant power. it might be a fuel pump issue.
    Mar 2011
    A, A
    maybe someone can chime in on the wiring part. im not sure the wiring diagram. search online for fuel pump wiring diagram. there shoul dbe a constant a ground one a 5v and one for 12v signal i beleive
    Jun 2012
    california
    i have change the fuel pump and it is getting a good ground
    Mar 2011
    A, A
    when you get the truck running. crawl under the truck and listed to see if the fuel pump is working. when the truck is forced to run it can create a vacuum in the fuel lines keeping the truck running at an idle.
    if the pump is working you gonna need to go to your locate napa and get a fuel pressure tester that will fit inline were you fuel filter is at and check pressure. could be mutiple things. the small hose in the tank that hooks to the fuel pump could be loose. could be bad pump. could be short in wiring harness. make sure your harness is not pinched between the frame and the fuel tank. many people dont pay attention to that. could be a bad relay. and yes even though you bought "new" pump and relay. the parts are electrical they may be faulty. could be a bad fuel in the dash. could be a bad connection somewhere. to many things to choose.
    like i said next thing is to check fuel pressure. check fuses, check to hear fuel pump noise.
    Jun 2012
    california
    when the truck was running i can hear the pump underneath in the tank working .but you said to check the fuel pressure on the tbi
    Mar 2011
    A, A
    what i said or ment was if you couldnt hear anything remove a line and check for pressure. but considering you say you hear fuel pump working. get a fuel gauge and check the pressure. since our trucks dont have test ports. you have got remove one of the lines off the fuel filter and hook (in line) the tester and check your pressure.
    Jun 2012
    california
    do you happend to know what the pressure should be at
    Sep 2003
    Catalina, AZ/Swartz Creek, MI
    A TBI engine won't create the vacuum needed to pull fuel through the lines, pressure is something like 13psi... anything close to that will be enough for the truck to run. Does it run well enough for a spin around the block? When is the last time your fuel filter was changed?
    Registered User 95BlackTahoe's Avatar
    Jan 2012
    Portersville,PA
    Quote Originally Posted by Doober View Post
    I was thinking the same thing that Doober suggested...A plugged up fuel filter could be the issue. On mine, I had a issue with the fuel pump connector. Keep that thought as well. New connector for me solved everything.
    Shawn
    Registered User jim_in_dorris's Avatar
    May 2007
    almost in oregon, but still california
    Put noid light on injectors then try to start. If noid light not flashing, check reluctor wheel in distributor for cracks /corrosion.
