Thread: Permanent Fixing: Chevy OBS Heater Coolant Quick Connect
Results 1 to 7 of 7
    Apr 2005
    NY
    For those who are still fighting for GM heater coolant Quick Connect, here is your final solution:
    Dorman Products released a heater coolant hose fitting directly replacing for OBS Chevy truck's Quick Connect, see following links, those fitting could save you a lot of money and time to fix the notorious Chevy Quick Connect coolant leaking.
    To do the job, you need cut off the rubber hose as close as to Aluminum crimper section, remove the Quick Connect with a deep socket. Be careful, the Quick Connect is made of soft metal, it could be snapped of right above its thread section. Then install Dorman hose fitting, re-attach -in (I.D.) rubber hose to the fitting, and secure the hose with a hose band clamper.
    1) Dorman Heater Hose Fitting 3/4 In. Hose x 1/2 In. NPT x 1-3/4 In. Long
    Dorman Part #: 500-005.1
    Advance Auto Parts Part #: 22972370
    http://shop.advanceautoparts.com/buy...500-005-1.html
    2) Dorman Heater Hose Connectors - 3/4 In. Hose x 1/2 In. NPT x 2-3/4 In. Long Nipple
    Dorman Part #: 56237
    Advance Auto Parts Part #: 5707439
    http://shop.advanceautoparts.com/buy...art-56237.html
    Dec 2011
    Lake City, MN
    Re: Permanent Fixing: Chevy OBS Heater Coolant Quick Connect
    I am wondering if this fitting has the restricter in it like the oem part so that the heater works properly ?
    Apr 2005
    NY
    I have used a brass hose burb replacing OEM Quick Connect for 40K miles on my 99 Tahoe, never had a problem. The brass burb was from Home Depot.
    Quote Originally Posted by mwall View Post
    Registered User 19silverado94's Avatar
    Mississippi
    I too installed a brass fitting for the heater hose going into the rear of the intake manifold, much better now for maintenance procedures!
    May 2006
    Alberta Canada
    went brass to,,,no issues
    [Stole/FOUND 13/03/08 :O)
    70 fury 3
    71 sport fury GT
    Truck Drivin' Sumbitch Scott Long's Avatar
    Jun 2010
    Salt Lake City, UT
    I got rid of the quick connect on my truck and have at thread in fitting that I wrapped with pipe tape, then I use a 3/4" hose and a clamp and problem solved.
    Lurker
    Dec 2004
    Portland Oregon
    To bring this back up from the not too distant past, The links posted by the OP are both for 3/4" hose. Is that correct? Do these trucks use 3/4" hose for both inlet and outlet to the heater core? Or is one 5/8" like the older stuff?
