Thread: TBI 350 Spark Plug Gap?
Results 1 to 20 of 22
    Registered User ChrisAU's Avatar
    Nov 2011
    Birmingham, AL
    I have a set of AC Delco Platinum #1's to replace the cheap NGK's I currently have in my truck, they come gapped at .045, should I re-gap to .035?
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Aug 2001
    New Jersey
    Re: TBI 350 Spark Plug Gap?
    Yup.
    Lanark, Ontario
    0.045 will run fine in a TBI with quality ignition components, IMO.
    When I ran my 6AL box in the 92, I had opened coppers all the way to 0.060 with absolutely no ill effects. After the 6AL box was removed I ran 0.044 on stock replacement ignition parts with no issue.
    Plug gap can be touchy subject as to it's benefits and drawbacks.
    Did you ever get your truck sorted out?
    Nov 2011
    Birmingham, AL
    Yeah, there was a short in the distributor and somewhere along the way I believe the first shop had pulled the plugs to inspect them and bumped a couple when putting them back in and closed the gaps, making the terrible miss when it got warm after I picked it up from the 2nd shop the 1st time. 2nd shop discovered that and re-gapped them, and then recommended I go back to AC Delco plugs. I've ordered some Rapidfire Platinum #1's.
    It still has a slight shake at warm idle, not really a rumble and certainly not a miss, but I really want it to be close to perfect because EVERYTHING is new. Also putting in a new AC Delco 195* thermostat because I believe I threw in a 160* or 180* when I got the truck (the one it had was stuck open), and the temp gauge never touches 200*, stays around 160-180 (hard to approximate), and the temp sender and pigtail in the block is new (that didn't work at all when I got the truck), so I'm wondering if the ECM is overfueling me a little bit once warm because its trying to warm it up but the low-temp t-stat isn't allowing the coolant to get hot.
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Lanark, Ontario
    IMO, cancel the order for the platinums and get some OE CR43TS plugs.
    Nov 2011
    Birmingham, AL
    Meh I had a bad experience with them, got some that were crap, haven't liked them since.
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Lanark, Ontario
    Quote Originally Posted by ChrisAU View Post
    Bad experience with AC Delco Coppers? Why continue with Delco's at all then, as the platinums are the same plug, but with platinum coating on the contacts.
    FYI Platinum plugs should be gapped very carefully or the platinum will be damaged.
    Nov 2011
    Birmingham, AL
    Would you consider all new AC Delco ignition components as quality? Wires, cap, rotor, coil, distributor, ICM, pick-up coil.
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Lanark, Ontario
    Absolutely. OE quality and all brand new.
    Nov 2011
    Birmingham, AL
    Ok...I may just check that they are all indeed .045 and throw them in and evaluate from there.
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    MI/AZ
    No dont throw them in carefully use antiseze and torque the plugs and make sure the wires are seated to the plugs and cap.
    Nov 2011
    Birmingham, AL
    Quote Originally Posted by redvett01 View Post
    Well that is what I meant haha
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Lanark, Ontario
    IMO, throw them in from 20ft to improve your accuracy, might take a few tries, but you'll get it.
    Nov 2011
    Birmingham, AL
    I was gonna shoot 'em in with a mini potato gun.
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Lanark, Ontario
    File the the 5/8ths nut part off and I bet they fit in a 12gau shell on top of the wad. Use a rifled barrel and they might spin right in to torque.
    Nov 2011
    Birmingham, AL
    Genius. This is why I come here, superior knowledge. Thanks!
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Lanark, Ontario
    May want to drop a towel over your fenders for protection.
    Nov 2011
    Birmingham, AL
    The truck already has a good bit of character...a spark plug halfway embedded in the fender would make for some interesting stories. "How'd that happen Chris?" "Well, you see..."
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
    Lanark, Ontario
    :lol:
    Nov 2011
    Birmingham, AL
    Alright, after I get my truck back this Friday from the transmission rebuild, I think we are going to have some bonding time Saturday in the form of a 195* t-stat, new oil pressure sending unit, transmission cooler, and these new AC Delco platinums I have.
    Just to be sure, I should be ok with the .045 gap, right?
    1992 ECSB 5.7L Z-71
    Past GM's:
    1998 ECSB 5.7L Z-71
    2007 Tahoe LT2 5.3L
    1999 ECSB 5.3L Z-71
    1992 RCSB 5.7L Z-71
    1993 RCSB 5.7L Z-71
