Thread: Where is the camshaft position sensor 5.7 vortec
Results 1 to 14 of 14
    Jul 2012
    ohio
    I have a 1996 k2500 with a 5.7 vortec. I need to replace the camshaft position sensor. Where is it located?
    Registered User MarkEagleUSA's Avatar
    Dec 2010
    CT
    Re: Where is the camshaft position sensor 5.7 vortec
    It's in the distributor. Are you getting any codes?
    Mark
    97 K2500, 5.7, 4L80E, 4.10 Posi
    Jul 2012
    ohio
    yes i was getting codes. How to I get the sensor free from the black circular ring that runs through it?
    Jul 2012
    ohio
    does anybody know? I got everything taken apart, I just cann't get the old sensor off of there
    Dec 2010
    CT
    There should be a notch in the ring that allows the sensor to be removed.
    Mark
    Jul 2012
    ohio
    got it. had to turn the key a little bit a few times to get the notch lined up. thank you sir
    Jul 2007
    East central Illinois
    Quote Originally Posted by daytonlax14 View Post
    Why is there a banner ad overtop of the log in spot?
    I found the first thread and clicked reply so the log in came up in a different spot. How annoying.
    1995 6.5 TD Tahoe
    Western NY state
    04 Avalanche Z71
    May 2011
    Arizona
    Quote Originally Posted by jrsavoie View Post
    Please explain to us exactly how your complaints contribute to this thread. Somebody has asked for help, not your childish whining about the site.
    If we're such an annoyance, you don't have to log-on. Easy fix, eh?
    Burnsville
    Not sure about a 96 but I have a 97 5.7 and my Cps is bolted to the back of the flywheel under the truck very easy fix. In the distributor is the ignition mod. Better double ck.
    Dec 2010
    CT
    Quote Originally Posted by MPLSFUNK View Post
    That's odd... on my 97 the CPS is in the disty and the ICM is mounted to a heat sink alongside the coil. I thought this is how all the Vortec's are configured, and every service manual or how-to I've seen says that as well.
    Mark
    Burnsville
    I dunno bro I'm @ the bar this may be a sloppy txt but the ignition mod is the only mod in the distributor. The ignition coil is what your thinking of I'm srry just trying to help I may be wrong no ones perfect but the Cps sensor is on the balancer under the truck. On my 97
    Mar 2011
    Canada
    i think you're talking about the crankshaft position sensor there bud
    Western NY state
    on 96+ crank pos sensor is by balancer, cam sensor is in dist. the ones with the module in the dist is 95 and earlier
    04 Avalanche Z71
