Thread: HELP! Hamonic Balancer Removal 05 Silverado 5.3L
Results 1 to 5 of 5
    Aug 2012
    Arkansas
    Exclamation HELP! Hamonic Balancer Removal 05 Silverado 5.3L
    I have a 2005 Silverado 5.3L 4WD, and Im replacing the Front Crankshaft Seal, and the Harmonic Balancer. Before I pull the balancer off the crank, do I need to note the position of the balancer in reference on the crank?? The harmonic balancer does not have a keyway, so do I have to worry about where it at on the crank? The instructions at AutoZone says that there no need to mark the old balancer before removing? Is this correct?? If I get the new one on, and not in the correct spot, will it cause it to vibrate excessively?
    Thanks in Advance.
    Vortec 6 ****in' liter V8 85-bowtie's Avatar
    May 2005
    Clarinda, IA
    Re: HELP! Hamonic Balancer Removal 05 Silverado 5.3L
    I never marked mine on my 6.0 and had no problems, I did try and get it close by looking at the marks that were left on the balancer and crank though.
    2002 ECLB Silverado 2500HD Duramax
    2003 ECSB Silverado 2500HD 6.0/ 4L80e totalled
    1985 RCSB C10 TBI 350/ 700r4
    Aug 2012
    Arkansas
    What marks are you referring too? I dont see any marks, other that 2 drilled out holes on the new balancer. I dont know if the old balancer has them or not, I havent pulled it yet?
    May 2005
    Clarinda, IA
    By marks I mean the wear marks or "stains" so to speak from where the balancer sat on the crank installed. Once it is removed you will see what I mean, but it's an internally balanced engine so it won't matter where the balancer sits.
    S.E. Wi.
    Sounds like a bugger to do and you have to use a new bolt.
    Service Information
    Crankshaft Balancer Replacement (4.8L, 5.3L, and 6.0L Engines)
    Tools Required
    J 41478 Crankshaft Front Oil Seal Installer
    J 41665 Crankshaft Balancer and Sprocket Installer
    J 41816 Crankshaft Balancer Remover
    J 41816-2 Crankshaft End Protector
    J 42386-A Flywheel Holding Tool
    J 45059 Angle Meter
    Removal Procedure
    1.
    Remove the air conditioning (A/C) drive belt. Refer to Air Conditioning Compressor Belt Replacement .
    2.
    Remove the fan shroud – lower. Refer to Engine Coolant Fan Lower Shroud Replacement .
    3.
    Remove the starter motor. Refer to Starter Replacement .
    Notice: Refer to Fastener Notice .
    Important:
    Make sure that the teeth of the J 42386-A mesh with the teeth of the engine flywheel.
    The crankshaft balancer is balanced as an individual component. It is not necessary to mark the balancer prior to removal.
    4.
    Install the J 42386-A and bolts.
    Use one M10-1.5 x 120 mm and one M10-1.5 x 45 mm bolt for proper tool operation.
    Tighten
    Tighten the J 42386-A bolts to 50 Nm (37 lb ft).
    1.
    Remove the crankshaft balancer bolt.
    Do not discard the crankshaft balancer bolt. The balancer bolt will be used during the balancer installation procedure.
    1.
    Use the J 41816 and J 41816-2 in order to remove the crankshaft balancer.
    2.
    Remove the J 41816 and the J 41816-2 from the crankshaft balancer.
    3.
    Clean and inspect the crankshaft balancer. Refer to Crankshaft Balancer Cleaning and Inspection .
    Installation Procedure
    Important:
    Make sure that the teeth of J 42386-A mesh with the teeth of the engine flywheel.
    The used crankshaft balancer bolt will be used only during the first pass of the balancer installation procedure. Install a NEW bolt and tighten as described in the second, third and forth passes of the balancer bolt tightening procedure.
    The crankshaft balancer installation and bolt tightening involves a 4 stage tightening process. The first pass ensures that the balancer is installed completely onto the crankshaft. The second, third, and forth passes tighten the new bolt to the proper torque.
    Important: The balancer should be positioned onto the end of the crankshaft as straight as possible prior to tool installation.
    1.
    Install the crankshaft balancer onto the end of the crankshaft.
    1.
    Use the J 41665 and the J 41478 in order to install the crankshaft balancer.
    2.1
    Assemble the J 41478 threaded rod, nut, washer and the J 41665 installer. Insert the smaller end of the installer into the front of the balancer.
    2.2
    Use a wrench and hold the hex end of the threaded rod.
    2.3
    Use a second wrench and rotate the installation tool nut clockwise until the balancer is started onto the crankshaft.
    2.4
    Remove the tool and reverse the installation tool. Position the larger end of the installer against the front of the balancer.
    2.5
    2.6
    Use a second wrench and rotate the installation tool nut clockwise until the balancer is installed onto the crankshaft.
    2.7
    Remove the balancer installation tool.
    1.
    Install the used crankshaft balancer bolt.
    Tighten
    Tighten the USED crankshaft balancer bolt to 330 Nm (240 lb ft).
    2.
    Remove the used crankshaft balancer bolt.
    Important: The nose of the crankshaft should be recessed 2.4–4.48 mm (0.094-0.176 in) into the balancer bore.
    3.
    Measure for a correctly installed balancer.
    If the balancer is not installed to the proper dimensions, install the J 41665 and repeat the installation procedure.
    4.
    Install a NEW crankshaft balancer bolt.
    Tighten
    4.1.
    Tighten the bolt a first pass to 50 Nm (37 lb ft).
    4.2.
    Tighten the bolt a second pass to 140 degrees using J 45059 .
    5.
    Remove the J 42386-A and bolts.
    6.
    Install the starter motor. Refer to Starter Replacement .
    7.
    Install the fan shroud - lower. Refer to Engine Coolant Fan Lower Shroud Replacement .
    8.
    Install the A/C drive belt. Refer to Air Conditioning Compressor Belt Replacement .
    9.
    Perform the crankshaft position (CKP) system variation learn procedure. Refer to Crankshaft Position System Variation Learn .
