Thread: What carb intake and TBI adapter plate are you guy using ?
Results 1 to 11 of 11
    Sleeper canadianstroker's Avatar
    Kelowna B.C.
    I mite put a nice carb intake on at the same time I do a head swap so I am wondering what you guys use and get out of it ?
    383 with no Manners or Respect
    94 EXCSB 4x4,383 TPI gone back to TBI, Custom Grind cam- 468/495lift 222/236 @ 50 114 LSA,Marine TBI Heads 2.02/1.60 ported/ polished, 10:1 comp, Headman LT headers,Tuned, built 4L60E
    Sep 2003
    Catalina, AZ/Swartz Creek, MI
    Re: What carb intake and TBI adapter plate are you guy using ?
    What heads? I have the GM spreadbore/egr intake (Vortec) on mine, and the TBi unit was bolted to a factory 454 spreadbore adapter, so I just used that. It's an open design (actually has a couple vanes to direct air/fuel) and seems to work pretty well, the engine is very snappy for having a long stroke. If I didn't have emissions to deal with I may have just put a 2bbl Vic jr on to see how that would've done.
    Kelowna B.C.
    A set of AFR 180cc.
    Quote Originally Posted by Doober View Post
    Welds Like Robot 907 Chevy's Avatar
    Aug 2009
    Anchorage,AK
    I'm pretty much running the same setup as Doober, a spread bore vortec intake with the GM big block throttle body adapter. I haven't fired the engine with the new intake setup because I'm waiting on some hose and hose ends to finish plumbing the intake so I can't give an opinion of this particular setup in terms of performance.
    I was using a square bore single plane intake with a 1/2" aluminum TB adapter, but switched to this present intake because cold weather drivability was downright atrocious. Hopefully the heated adapter will solve the drivability issues I was experiencing.
    DD: 1989 Taurus SHO
    Project:1995 ECSB,Auto-5 speed manual conversion,Vortec 357,LT4 Hotcam
    Sep 2003
    I would've liked to compare the open 454 adapter to the 2-hole spacer but it was the same time I switched heads.
    Aug 2009
    Anchorage,AK
    I like the open design of the stock big block adapter and it adds a good amount of plenum volume as well. That's almost always a good thing from a performance standpoint...to a certain extent, of course.
    The fact that you can plumb coolant through it pretty much sold me on it.
    DD: 1989 Taurus SHO
    Kelowna B.C.
    thanxs for the input guys...I run a sb 2"bored tb.Since I don`t have to match vortec head angle I have a few more choices in the intake.
    Aug 2009
    Anchorage,AK
    Do those AFR's have an exhaust crossover?
    DD: 1989 Taurus SHO
    Sep 2003
    I know several of their heads are 50-state legal, so it wouldn't surprise me.
    Jul 2010
    USA
    EdelbrockPerformer RPM. If you want a bit more plenum volume, and possibly improved velocity/atomization (up for argument), slap a phenolic spacer on top of it. Being that you're in the great white north, I'd stay away from the "airgap" style intakes because of the cold run-ability issues you'd have.
    '96 K1500 SUBURBAN
    Kelowna B.C.
    Air would be death to cool...-10C today here
    Quote Originally Posted by SUBURBIAN View Post
