Thread: 4L60E transmission issues, help please!
Results 1 to 13 of 13
    Jul 2012
    WA
    hey im new to the site and i need some help.
    i recently recieved my corvette servo for my 99 Silverado 1500 NBS. i decided while i was wrenching on the trasmission i might as well replace the filter and fluid. Bad Idea. i got the new servo installed and went to pull the pan and of course it was a pain in the ass and i ended up breaking the connector off the 2-3? shift solenoid i think. i went to the parts store and got a new solenoid installed it put the pan back on and filled to the appropriate level of fluid. warmed the truck up and took er for a spin. there feels like itd not engaging in D, 3 or 2. only in first. im at a loss. any help is appreciated.
    LM7 Outlawz2004's Avatar
    Louisiana
    Re: 4L60E transmission issues, help please!
    You got it filled enough? Should take about 5 quarts if I remember right for a fluid and filter change. Check the fluid level after it gets up to operating temp.
    Jul 2012
    WA
    I put about 5 quarts in and took it down the driveway and got a service engine soon light so i came back to the house and checked the fluid, it was low so i added more and it didnt fix the problem unfortunately.
    Louisiana
    contact transbuilderguy, he knows all about them. He is currently building me a trans, but I believe he told me he was going to be out of town until around Wed, but he may reply if you send him a message.
    Jul 2012
    WA
    Thanks, ill do that.
    Jul 2012
    WA
    i just plugged in a diagnostic machine to my truck and got PO758 code. anyone knows what that means?
    Sep 2011
    Washington
    p0758 is the shift b solenoid.
    Jul 2012
    WA
    is Shift b the 2-3 or 1-2?
    Sep 2011
    Washington
    Quote Originally Posted by scarpzimmerman View Post
    I believe the B solenoid is the 2-3 shift.
    Jul 2012
    WA
    Im hoping that maybe i just aaccidentally disconnected the solenoid when installing the tranny pan...i guess i get to get covered in tranny fluid and bash my knuckles up some more. wish me luck.
    Nov 2006
    Texas, Coast
    When I went to replacing mine the connect lock tab was broken so I placed a small tie wrap so it wouldn't come loose consider that it as well.
    Hnic at transbuilderguy
    May 2010
    Gainesville, FL
    I wouls say you probably broke the shift solenoid with the trans pan tryig to shimmy it past the exhaust happens alot there are 2 of them at the rear of the valve body they are both the same its the 1-2 and the 2-3 solenoid. if the locking tabs are broken replace the case harness also.
    check out my customers group
    904-402-6016
    Jul 2012
    WA
    Well since I got the code for the shift solenoid I took the pan back off just enough to reach my hand inside and feel the connector ans sure as **** it was disconnected. I plugged it back in threw the pan back up, filled her with fluid and took it for a spin. Shifts like a dream now. Corevette servo is pretty cool upgrade. Luckily I only managed to smash 9 of my knuckles in the entire process but my truck is back on the road. Thanks for the help guys.
