Thread: Spark plug reach and gap... 97 5.7 liter vortec k1500
Results 1 to 6 of 6
    Colorado
    I have been researching and googling this tirelessly the last few hours, as far as i can tell my spark plug gap is .060, but to make things more confusing for me, i read some stuff that a service bulletin recommended gapping to .040" instead of the oem recommended. Is this true for my year of vortec?
    Also curious what i should be looking at as far as spark plug reach. When i search spark plugs on summit racing it comes up with several different options that fit my truck, some with a reach of .708" and some with .691" and .690". Are these so close that it wont matter?
    97 Z-71 x-cab 5.7 liter,
    6" Rancho, 3" PA BL
    315-75-16 BFG MT's 16x10 Pro Comp alloys,
    Flowmaster single in, dual out,
    Gibson Shorty headers,
    Airaid CAI, airaid TBS,
    Jet mass air flow sensor
    Nelson Tune, Precision 4.56's with Truetrac,
    And a mossy oak steering wheel cover!
    I love chrome SoSoFLY's Avatar
    Feb 2012
    Edmonton AB Canada
    Re: Spark plug reach and gap... 97 5.7 liter vortec k1500
    The reaches are so close that it doesn't matter.
    I believe .040 is the spark plug gap you should be using.
    DD -07 Illverado, 5.3, Airaid, 4/6 mcgaughys deluxe drop, HID projectors, LED in/out, colormatched ext/int, chrome U2 55 24x10, 15% over factory, rollpan, RST spoiler, lots of mods
    Registered User jesse82nc's Avatar
    Feb 2013
    Clayton, NC
    I was about to change them on my 96 tomorrow, I was going with 060 but if it should be 040 I would like to know.
    -Jesse, '96 C1500 5.7L
    -Jesse
    1996 C1500 - 5.7L - 2WD - 4.56 14-bolt G80 - Tuned
    Whipple Supercharger, Headers, custom mandrel bent exhaust, Flowmaster 44s
    Race built stage 4 4L60E
    3" BL, 4" Spindle Lift, 43" at the fenders, 32" tires
    Woodstock Ontario Canada
    Stay with the 0.060", thats what the factory spec is. The coil used on the vortec is significantly hotter than teh TBI trucks. Its teh same coil as used on the LT1/4 LT1's.
    The reachon the Vortec and non Vortec ehad is different and is known to cause issues if mixed. But the specs you supply are pretty close and shoudlnt matter I would think.
    peace
    PAuly
    Colorado
    Does the .040" bulletin not apply to my year of vortec? Another instance where one guy says 060, another says 040. Is anyone running .040"in their obs 5.7 liter?
    6" Rancho, 3" PA BL
    Aug 2009
    C.A. High Desert
    here is the TBS on the plug gap change..
    Subject: Information on New Spark Plugs and Gapping #03-06-04-060 - (10/24/2003)
    Models: 2004 Buick Ranier
    2002-2004 Cadillac Escalade, Escalade EXT
    2003-2004 Cadillac Escalade ESV
    2004 Cadillac CTS-V
    1997-2004 Chevrolet Corvette
    1998-2002 Chevrolet Camaro
    1999-2004 Chevrolet Silverado
    2000-2004 Chevrolet Suburban, Tahoe
    2002-2004 Chevrolet Avalanche
    2003-2004 Chevrolet Express, TrailBlazer
    1999-2004 GMC Sierra
    2000-2004 GMC Yukon, Yukon XL
    2001-2004 GMC Yukon Denali, Yukon XL Denali
    2002-2004 GMC Sierra Denali
    2003-2004 GMC Envoy XL
    1998-2002 Pontiac Firebird
    2004 Pontiac GTO
    2003-2004 Hummer H2
    with 4.8L, 5.3L, 5.7L or 6.0L V-8 Engine (VINs V, P, T, Z, G, S, N, U -- RPOs LR4, LM4, LM7, L59, LS1, LS6, LQ9, LQ4)
    A new spark plug has been released for use in the above vehicles. The new spark plug has an Iridium tip instead of the current Platinum tip. Due to the different tip design, the gap of the spark plug has also changed. The new spark plug, P/N 12571164 with AC Delco P/N 41-985, is gapped to 1.01mm (0.040 inches) when the spark plug is made. The spark plug gap is set during manufacturing and should not be changed or damage to the spark plug may result. Any new spark plug found to not be properly gapped should not be used.
