Thread: Best cam for a 350 tbi
Results 1 to 20 of 29
    May 2013
    Pennsylvania
    Whats the best mild cam for a currently stock 350 tbi that will still be a good daily driver
    Sep 2003
    Catalina, AZ/Swartz Creek, MI
    Re: Best cam for a 350 tbi
    Do you have any other plans for it? What gears do you have? Sometimes that's an easier upgrade than a cam, and usually will feel a bit peppier in town. With any cam it will need a tune to run at optimum, but for what you're looking at, no other changes to drivetrain, etc., stay under 210@.050". TBI heads need a bit of work in order to breathe up top, so it won't do much good to get more aggressive on timing.
    May 2013
    Pennsylvania
    Got the stock Z-71 gears which are 3.73 i believe. and do you know anywhere to get 4.56 gears online??
    Jun 2013
    Manchester NH
    summitracing but requires a new sized carrier for gears bigger then 4:10 because of ring gear being to big pushing out into the diff cover....
    May 2013
    Pennsylvania
    do you have the link?
    Oct 2005
    Kentucky
    Quote Originally Posted by Bbell View Post
    my stock Z71 gears were 3.42....just so you know
    May 2013
    Pennsylvania
    well my axle dont have a tag and the numbers in the glove box are wore off so i cant tell.
    Jul 2010
    USA
    Saying you have Z71 stock gears is like saying you have the Z71 stock color, guys. This false Z71 bravado never ends. 2 ways to tell gear ratio now...remove the cover and count then divide the teeth on the ring and pinion or jack up the back of the truck, spin the tire, and count the driveshaft revolutions. They make ring gear spacers to run certain gears with other carriers....done all the time, just not recommended for extreme duty applications.
    '96 K1500 SUBURBAN
    May 2013
    Pennsylvania
    Quote Originally Posted by SUBURBIAN View Post
    The driveshaft does 4 turns to 1 turn of the tire. What's that telling me?
    Jul 2010
    USA
    It sounds like you could or most probably do have a 4.1X ring/pinion set...which is one of the numerous "stock" Z71 gear ratios.
    '96 K1500 SUBURBAN
    May 2013
    Pennsylvania
    What ratio is that?
    Lanark, Ontario
    A poorly marked one I bet. You are half way between gear ratios.
    May 2013
    Pennsylvania
    And that means?...
    Lanark, Ontario
    And that means?...
    Means you should have come up just less than 4 (3.73) or just more than 4 (4.10).
    May 2013
    Pennsylvania
    Well actually at EXACTLY one tire rotation the driveshaft had spun ALMOST 4 turns.
    Oct 2005
    Kentucky
    I dunno about stock gears but I did see 4.11 stamped on my Yukons when they were put in. Do stockers have a stamping on the ring gear?
    Sep 2003
    What I've seen is a tooth count (i.e. 41-11, which would be 3.73) on the ring gear.
    Mr.RiverRat
    Mar 2013
    Vicksburg ms
    I'm curious about cams too. I have a 350 tbi stock besides exhaust and open Element air cleaner. I wanna run 3.73 gears and run vortec heads but stay with my tbi maybe a bigger one from SPR preformance.
    Any suggestions?
    May 2013
    Pennsylvania
    I'm weary about doing a cam because ive heard you have to change the cam bearings and tuning seems like a pain in the butt
    Sep 2003
    If you run an EBL like I do, it's actually quite easy, just time consuming. I understand burning chips isn't so bad once you get the hang of it, but I'd rather run an EBL for flash capability.
    So long as the cam bearings are in good shape you can likely reuse them, but if it has a lot of miles I would change them. A shop won't charge a ton to change them, but I don't know if you're getting that far into the engine.
