Thread: 14s possible tbi l31
Page 1 of 6 123 ... LastLast
Results 1 to 20 of 105
    Aug 2011
    Fort Worth, Texas
    Hi all just wondering if this combo with drag radials eaton tru trac and and trac bars get me in too the mid low 14s in a 4000lb swb obs? 700r4 Tranny
    L31(stock)
    Edelbrock Performer 2116
    454 Tbi (supporting mods)
    Shorty Headers
    3" Y-pipe
    1.6 self aligning rockers
    S10 Stall
    Corvette Gorverner
    Shift kit/servo
    4.10 gears
    EBL Flash tuning
    Eaton Tru trac
    Assassin Tractionbars
    Let me know what you guys think dont care to get my feelings hurt.
    Registered User southcarolina13's Avatar
    Feb 2012
    south carolina
    Re: 14s possible tbi l31
    i would think so. a 2011 v6 mustang that weighs only like 500lbs less will do low to mid 13's stock.
    Aug 2011
    Fort Worth, Texas
    I was thinking maybe down 240rwhp at the most have over 300+TQ with traction and gear combo should put me in the high to mid 14s. Anybody with real world experience chip in?
    Registered User 1998454's Avatar
    Jan 2011
    west virginia
    Should run 14's. I see a trans build coming up too.
    Euless, Texas
    Quote Originally Posted by 1998454 View Post
    Or 4L80e with a 4.3 G-Van converter, but I am just weird. Back in the day I put a 4L60E in my old 88 2.8 S15 Jimmy and swapped in a custom chipped 7427 TBI PCM from a 95 Astro Van to run it.
    Euless, Texas
    Quote Originally Posted by tolow4phathoes View Post
    With good tuning and those bolt-ons I think 260 hp to the tires is doable. I have seen many stock L31s in the 200 rwhp range.
    Sep 2003
    Catalina, AZ/Swartz Creek, MI
    That stands to reason since they were rated at 255 and 15% loss is around 215.
    http://www.wallaceracing.com/et-hp-mph.php
    4000lbs. and 260rwhp puts you at 14.5, so if you're making 300 at the crank that's around where you should be.
    Aug 2011
    Fort Worth, Texas
    If I could squeeze out between245-260 rwhp 320+tq with out a camshaft swap I would be very happy on a stock compression l31. Truck will only go to track maybe 3 times out of the whole year. just trying to have a mid 14s swb obs dd no cam swap if at all possible. I am thinking it is and hope to set out and reach that goal. WIll also be sprayed 100 shot on occasion will be rare though.
    Euless, Texas
    Considering I have seen an ECSB TBI run low 15s, with stock swirl port heads and a beyond weak Edelbrock 3702 cam, it is definately possible.
    Aug 2011
    Fort Worth, Texas
    Do you have a intake manifold you recommend for a otherwise tbi l31? Im thinking the Performer 2116 will do?
    Euless, Texas
    The 2116 runs out of steam faster than the stock cam does. I would look at the 7116 and give yourself room to grow. I am more of a fan of the 2912 however on a TBI, but tuning can present challenges on that one.
    Jan 2011
    west virginia
    I didn't know they ever used an 80e behind a 4.3
    Quote Originally Posted by Fast305 View Post
    Euless, Texas
    Yep 3/4 and 1 ton vans had the 4.3/4L80E combination. You could also get the 305 in front of one in the 2500 Express. The newer express vans run the 4.8/4L80E. The information I have found, suggests all 3 setups used the B82 high stall 4L80E converter.
    Jan 2011
    west virginia
    Good info. That would be the trans to find at the parts yard, the 80e would have had a good stress free life behind a 4.3.
    Aug 2011
    Fort Worth, Texas
    7116? Im trying to have power from idle-5500 rpm and alot of low end tq and midrange power.
    91 GMC Sierra ST gmc406's Avatar
    Jan 2008
    Canada SK
    What's your altitude?
    Aug 2011
    Fort Worth, Texas
    500 ft. above sea level.
    Euless, Texas
    Trust me on it I ran the intake you have in mind and two others after that. The performer rpm will still snap your neck back and breathe past the cams useable powerband. I have used them on stock stalled and geared 305 powered vehicles.
    Jan 2008
    Canada SK
    If you haven't had it dyno'd, don't guess at your power level. You may walk away very dissapointed.
    I think 14's is a stretch, IMHO.
    When you going to the track?
    Sep 2003
    Track doesn't lie, you can calculate HP from MPH or ET and weight. I calculated mine to about 155hp at the crank, after figuring altitude and 15% driveline loss. This was in 2010 at SIR in Tucson.
