Thread: Will the rear end from a 93 fit a 99
Results 1 to 11 of 11
    Sep 2013
    shutesbury
    Hi, I'm trying to replace the rear end on my 93 silverado. The rear end is shot and I found a 99 rear end same gears (3.73) as my truck but it has disc brakes (bonus). I need to know if it will fit naturally or if there will be modifications needed (beside brake lines) to mount it up. Any help and advise would be greatly appreciated, Thanks in advance.
    The Warden cedjunior's Avatar
    Jul 2003
    Irving/Valley Ranch, Texas
    Re: Will the rear end from a 93 fit a 99
    It's been a while but I think the spring perches/shock mounts have to be moved.
    1995 K1500, 350, NV4500, 9.5" rear axle
    2009 Pontiac G8 GT 6.0 - 361/385 Stock Cortex Tuned
    Euless, Texas
    Quote Originally Posted by cedjunior View Post
    Very possibly need to be moved. Although I did measure a newer 03 C1500 6.0 9.5" 14-bolt SS rear end today and it matches the spring perches and axle width on a 97 Express, so atleast some things stayed the same. Although I will have to relocate the shock brackets and bump stops. Just saying it can be done, but it might be more trouble than it is worth.
    TN
    You need to be a lot more specific.
    A 93 1/2 ton 3/4 ton or 1 ton.
    A 99 1/2 ton 3/4 ton or 1 ton. Or suburban/Tahoe/Yukon?
    98 was the last year of your body style, 95 and 96 were the big changes. Different interior, mirrors, grill, then different motor trans.
    However if you have a 3/4 or 1 ton it would be the same body up to 2000.
    If a 1/2 ton a suburban or Tahoe rear will fit.
    2wd and 4wd need to be the same. (if yours is 2wd you need a 2wd rear)
    So what do you have? And what is the new axle out of?
    05 Cavalier
    FastOrange BlacK20's Avatar
    Nov 2010
    Williams Lake, BC!
    Quote Originally Posted by kcb37 View Post
    :word:
    also in 99 you could still get a 98 style, called a "classic" came in 1/2ton 2 or 4 wheel.
    Sep 2013
    shutesbury
    I have a 93 1/2 ton silverado 4wd k1500 p/u and the new rear end is from a 99 silverado 1/2 ton 4wd p/u. I also was wondering what changes will need to be made to accomodate the fact that the new rear end is disc brake. Thanks again, the help is invaluable as I've only been working on my own vehicles for a couple years now and have yet to really do anything major aside from replacing stock parts with stock parts.
    i saw what you did there fast68chevy's Avatar
    Apr 2003
    spring perches mainly, yeah,. alot or most of the 8.5" truck housings have two sets of perch mounts welded to the tubes though
    almost always.
    i dont think ive seen one without two sets them actually
    a tape measure will answer for you real quick
    text Randy @ 217 671 7792
    1993 C1500 pickup 162k 4L60E 3.08 w/1991 4.3L TBI w/ 260k+ '79 C-20 350/TH400 3.73 14FF '82 K-10 S/F, '72 Chevelle SS 454 -57 Bel Air gasser '68 Corvair Monza, '54 F350 '61 dodge mail step van! pics: parts photos
    Jul 2003
    I think that second set of spring perches you're talking about are just bump stops.
    Nov 2010
    Williams Lake, BC!
    Quote Originally Posted by boohardy7 View Post
    99 old style? Or new?
    TN
    disc brakes it's new style.
    I would agree I have never seen any axle with 2 sets of spring perches. 2nd set should be bump stops.
    05 Cavalier
    TN
    05 Cavalier
