Thread: Converting 8 lug to 6 lug?
Results 1 to 9 of 9
    Na und? PtownZ71's Avatar
    Dec 2001
    Tallahassee, FL
    Question Converting 8 lug to 6 lug?
    alright, guys, i recently got a chevy 14 bolt with a detroit locker, for get this, free b/c my dads best friend wrecked his chevy and he just gave it to me!
    now, it has 8 lug axles, and i have 6 lug. can i have these axles converted to fit my wheels safely and for a decent price? or am i better off to find an axle manufacturer and have them make a set? dont know if they are different or not, but i need to use my brakes if possible, b/c my bud already gave his away. any suggestions on companies, manufacturers, etc?
    will my driveshaft need to be shortened? i already know i need a different yoke.
    any problems i might run into, or things i may have short sighted?
    sorry for all the quesions, im just getting into working on rear ends and such. thanks
    2007 Silverado 2500HD Duramax. Stuffin' 20s wrapped in 36" Nittos. No lift.
    Observationalist James B.'s Avatar
    Dec 2001
    Unfortunately, if your fourteen-bolt axle's got an 8-lug pattern, it means that it is a "full-floater" That extra hub sticking out, with bolts of it's own, allows the axle shafts to be removed without pulling the wheel, drums, brakes, bearings, etc. The Full-Floater 14-Bolt has a 10.5" ring gear.
    The "Semi-Floater" version of the 14-bolt can be found under "heavy halft-ton" trucks of two generations ago. (Not duallies and not diesel) These rears have a 9.5" ring gear. They also already have the 6-lug pattern.
    Give DriveTrain Direct a call, http://www.drivetraindirect.com and talk to Jason. These guys can build a 10'5" semi-floater. They call this setup bulletproof for good reason. Maybe they can convert yours to the appropriate hardware. They are in Corona, CA. (909) 272-0158, (800) 584-4327
    Hang on to that thing until you find a place that can do the work - it's VALUEABLE!
    "James B." '99LT_Tahoe4Dr2WD, Tuned L29 Vortec 454, 62#Injectors, MSD6A, Six 3"mufflers, 10.5"non-float14bolt ,EatonPosi, 4.56:1, Built4L80E, Gear_Vendors, Splined_Driveshaft, HydroBoost, Be-Cool_Rad., FAL-292fans, Tracbars, Swaybars, AirRide, etc.
    Dec 2001
    BC
    ptown,
    is it a 99+ 14 bolt or an older one with drum brakes ??
    Dec 2001
    Tallahassee, FL
    no it has disk brakes
    it is from a 2000 silverado
    Dec 2001
    It's got discs eh? I have no idea what to do with those...
    As for your driveshaft length...
    I've been told the pinion on the 14-bolt is sticking out just over an inch more than the 10-bolt. If this is true, you will probably not have to shorten your driveshaft becuase you've got a 6" lift. You'll notice that the slip yoke is out farther with the lift than it was at stock height. If you did not have it lengthened when you did the lift then you shouldn't need to have it shortened for the 14-bolt.
    Did you talk to Jason? He drives a lifted 4x4 Yukon (old style) with a 10.5" 14-bolt under it. I talked to this guy for a solid 10 minutes a few weeks ago. Knows what he's talking about. I'm holding out for Eaton's 14-bolt Posi to be released next month.
    Dec 2001
    Tallahassee, FL
    no i havent talked to him yet. i was going to het to it today or tomorrow, just been so freakin busy lately....
    i'll let you guys know if i find anything
    Dec 2001
    BC
    its kind of a long shot, but I have a set of 9.5" 6-lug axles (no there not for sale) that I can measure up, if they are the same you could just get a p/n and buy oem ones. If they are short you are sol, if they are slightly long, you could get the spline end shortened and c-clip re-cut. I'll dig them out this weekend.
    Dec 2001
    Tallahassee, FL
    thanks alot!
    i appreciate your help
    Dec 2001
    BC
    ok, the axles are from a 97 14 bolt 9.5" 6-lug
    distance from c-clip to wheel flange 32-3/16
    diameter of end bearing surface 1.700
    c-clip groove diameter 0.820
    33 spline 1.420 diameter
    hth
