Thread: If i cut my tail pipe...?
Results 1 to 12 of 12
    Tow/Haul Wh*re Sierra4x4's Avatar
    May 2002
    Austin, Texas
    For some reason my 4.8 is really quiet and i was wondering...if i cut my tail pipe off closer to the muffler would it make it louded?...i have heard one cut off before and it had a nice little hum and im too poor for a 40 series and im looking for something to do to my truck...its sunday, im bored and i have a grinder =/
    00 GMC Sierra 4x4, K&N, 35% tint, CompuStar and cranked, 285 BFG AT's
    12 Second Truck Club Rollin20s's Avatar
    Nov 2002
    Greenwell Springs, LA
    Yes, it does make it louder, but not very much at all. When i dropped my truc, i hated the look of the the tailpipe sticking out, so i took a bann saw and chopped it off. It wont hurt anything so go ahead and do it!
    06' Sierra 2500HD CCSB 4x4 - LBZ/Ally - current
    07' Silverado ECSB 5.3 - SOLD
    98' Z28 M6/LS1 - SOLD
    00' Corvette FRC M6 - SOLD
    02' Z28 M6/LS1 - SOLD
    02' Silverado RCSB 6.0 - SOLD
    99' Silverado ECSB 5.3 - SOLD
    99' Silverado RCSB 4.3 - SOLD
    Mar 2003
    Houston, DE
    Just cut the whole muffler off, it will sound pretty sweet, and it will be loud. You may loose a little backpressure but if you get some dual pipes or even a single and run it back it will help some and get some tips to smooth out the sound a bit. I think you will be impressed with it. Total cost should be under $150 bucks probably. Unless you just chop off the muffler. Goodluck!
    May 2002
    Austin, Texas
    I think i wanna keep the muffler but i want the tail pipe gone....where should i cut at, before or after the rear axle?
    Dec 2002
    /home/andy
    Keep the muffler on, texas cops aren't fans of mufflerless trucks, and they sound pretty crappy IMO.
    I'd just cut it where it looks good...
    Rest in Peace Jason Payne
    Registered User Xx_surveyor_xX's Avatar
    Jun 2003
    Burleson, TX
    I CUT MINE RIGHT AS IT CAME OVER THE REAR END...IT LOOKED KINDA LIKE A FACTORY DUMP EXHAUST PIPE
    " IF YOU DONT LIKE ME GO NOT LIKE ME SOMEWHERE ELSE "
    NCM!TB!LGB!YBWOB?
    Feb 2002
    Tonyville
    you could cut it right after the muffler, and that should be loud, but it will give you interior resonance
    LET'S GET ROCKIN'!!!! BIGBADSILVERADO's Avatar
    Mar 2002
    Brookfield, Connecticut
    DITTO THAT!!!
    That's why I RE-INSTALLED my tailpipes!
    Nothing worse than cruising on the HIGHWAY and listening to that muffler resonating the cab to death!!!
    Tom Fox
    Brookfield, CT
    2000 Silverado EXT. Cab Short Bed Z71.
    RCD 6" Lift - PA 3" Body
    NCM!TB!LGB!YBWOB?
    Feb 2002
    Tonyville
    Originally posted by BIGBADSILVERADO
    DITTO THAT!!!
    I've ridden in my friends truck on the freeway, and the noise level is pretty bad with true duals to flow 40's that are dumped, its not as bad as it used to be, but if it were mine, I couldnt stand it
    Registered User Way2Fst4u's Avatar
    Jun 2003
    Leominster, MA
    Is that because of where they were dumped? I was thinking of cutting mine back by the axle to lose the ugly tailpipe hanging out...but I really don't want that cab resonation.
    Thanks!
    ___________________________
    Jun 2003
    Burleson, TX
    mine didnt have any resonation when i cut mine at the rear axle but then again it is just a 6-banger.
    joe
    Ford... ha ha ha
    Oct 2002
    Baton Rouge
    If you cut the tips off, you can install turndowns about 1-2 ft before the bumper. You wont see anything, and you wont have as much resonanace because youre not dumping right under tha cab. You'll also get better performance if you have at least 10 inches of pipe before your turndowns -- ask flowmaster.
    1990 single cab
    5/7 Drop
    383 Stroker
    Eagle cast 383 crank
    5.7" Rods
    Keith Black Hypereutectic Flattop Pistons
    Holley Systemax Aluminum Heads (63cc chambers)
    Comp 292 (230/230@.050 109LSA) Cam
    Edelbrock Performer RPM Air Gap Intake Manifold
    Edelbrock 750 Performer Carb
    Wilson Manifolds 1.5" Aluminum Carb Spacer
    Taylor Thudnervolt 10.4mm wires
    Accel Shorty Header Plugs
    MSD 6-AL Ignition
    Ceramic Afterburner Headers
    Custom Stainless X-pipe
    Flowmaster 40's
