Thread: 350 TPI Motor in a 1992 Chevy Silverado
Results 1 to 5 of 5
    Nov 2003
    Alaska
    I was wondering where I would locate a company that burns chips for this type of setup. The motor is running but it misses a lot because it is using the original Silverado ECU/Computer. I am looking to get a Vette ECU/Computer and have it sent off to someone who can program it for my truck. Or if there is any better way please let me know!
    I am also new to this site.
    Thanks for the replies in advance.
    Built Chevy Fast BigRedChvy383's Avatar
    Nov 2002
    West Portsmouth, Ohio
    here's the site for you www.ecmprogrammer.com he's the best for tunning pcms
    2004 GMC Sierra, RCSB, 5.3, A4, 3.42s, G80, AEM Brute Force CAI, TB Coolant By-pass, Corsa Sport Cat-back, HP Tuners Pro Suite.
    1991 Chevrolet Silverado ECSB - Forged/Brodix/Demon 355, T56, 4.56s, Auburn Pro-Series, NOS Sniper Kit, and some other stuff.
    technut
    Sep 2001
    north little rock, arkansas
    i kindda do this for a living....
    questions?
    1. what computer are you currently using?
    2. what chip are you using?
    3. fuel pressure is?
    4. what injector are you using in your TPI setup?
    5. what inital timing have you set?
    6. using a data scanner,what kind of MAP voltage do you have?
    7. are you using EGR?
    8. what internal engine modifications have been done?
    airdeano
    ? horsepower
    ? torque
    will find out soon!
    1965 C10 5.3L (SSR) TH4L60e
    Nov 2003
    Alaska
    The good... and the bad...
    1. I am using the Stock ECU from the truck.
    2. No chip yet.
    3. Base Fuel Pressure
    4. Stock Vette Injector
    5. Base Timing
    6. Havent tried this yet.
    7. No EGR
    8. No engine mods besides the stock 350 TPI Engine.
    I am actually very new to this... I need to know exactly what is a "must" mod in order for the engine to run properly, or atleast half way decent, and what should be done in the future. I just want to get the engine working and from there I can start modding the engine. I currently am however just looking to get the engine working correctly. This truck was originally done with the intentions of visual appearance but I was able to pickup the vette motor for 600 bucks so it seamed like a steal of a deal.
    Thanks again.
    technut
    Sep 2001
    1. to be honest, yes the 7730 computer is a better to be using
    because the TBI was only designed to drive two injectors not eight
    the TPI has.
    2. the GM TBI uses 55lb/hr injectors x two and fires the TBI twice
    per crankshaft revolution. the TPI uses 19lb/hr (305) 22lb/hr x eight and fires twice per crankshaft revolution.
    this means the TBI uses 220lb/hr of fuel @ 9-13psi
    the TPI uses (19lb/hr injectors) uses 304lb/hr @ 37-42psi
    the TPI uses (22lb/hr injectors) uses 352lb/hr @ 37-42psi
    so you are under fueling the TPI with stock TBI programming.
    its LEAN LEAN LEAN!!!
    3. base is?? stock TBI 9-13psi of TPI 37-41psi?
    4. youll need to get one or have a custom chip burned with the truck
    present for the tuner.
    5. ok
    6. fine...
    replace the TBI computer with the 7730 computer. repin the outputs,
    youll have to either use a signal generator for the speed input for the
    torque converter dakota digital SGI-5), or use a manual lock up kit.
    youll have to use a custom chip to burn the VATS when you do the
    computer swap or use a VATS bypass to enable the injectors to
    start.
    airdeano
    ? horsepower
    ? torque
    will find out soon!
