Those pumps work best when at full flow, so the regulator at the TB is a bypass regulator. All it does is keeps the pressure in the line in front of it at whatever it's set bypass pressure is, so the injectors always see the same pressure. Anything that the engine doesn't use gets returned to the tank through the return line.
Mark
(aka: Silverback, WS6 TA, JYDog, 83 Crossfire TA, mpikas, mmp... on other boards and lists)
