Old 05-20-2004, 02:07 PM   #8
2doortahoe95
Member ID: 14988
Just did my water pump on my 95 tahoe, yesterday. In reply to geno96z71, I was having leak probs too. I thought it was the lower hose but found it to be the quick disconnect fitting on the hose that screws into the top of the waterpump. Everytime I would shake the hose it would spurt out.
Might want to remind people, everytime you change the water pump to replace this fitting otherwise you might have leaks. I also found those hose clips to be a bizatch to clamp without big pliers or the specific hose clamp tool. Ended up using a grip clamp/c-clamp to open the clip.
1995 2 Door Tahoe stock but ready to
ROCK! I need mud tires!
