Originally posted by chevyforu
If you install an injector pod spacer the extra 1/4 inch may make enough room to adjust the regulator.
Actually, the problem I had:
Where the stock regulator sits, it sits in a "seat".
That 'seat' covers up and seals in the location JET placed their adjustment screw.
IMO: They should have mounted it on the side with some sort of ring gear or slide mechanism.
