Old 09-16-2004, 07:22 AM   #18
Outlawcrewcab
Not a preferred vendor
Outlawcrewcab's Avatar
what do you need to know? use a spray bottle with soapy water and spray on the joints when its aired up. when you find the leak fix it. if its where metal fittings are pul apart and put some pipe dope on it. if its where a hose goes into a contector it will depend on if its a push in or a compression fitting
Outlawcrewcab is offline   Reply With Quote
