Old 10-12-2004, 11:41 PM   #22
truckin92pu
truckin92pu's Avatar
Re: Advice on bagging a truck
Ok i have a few of questions, i apologize in advance if they are stupid but i am interested in bagging my truck and dont understand how the supension must be set up.
1) I would like to use the air ride coolride uca/lca set up in front, where does the bolt on shock mount go? and what does 04_low mean by saying he pulled the bolts out of the frame? is that a common problem?
2) When installing a new uca for air bags how do you set up the eccentric for camber adjustment? Can the eccentric be marked and just reinstalled in the same position. Can it be aligned at a shop if the suspension is now on airbags?
3) Is the pinion angle affected when using airbags. How should the angle be setup or does the suspension kit installed in the rear compensate or find the correct angle itself?
This has been very informative and i would greatly appreciate any info. Thanks for the help.
92 RCSB
350 TBI w/ 700r4
4/6 drop
AMERICAN RACING TORQUE THRUST II
18X7 FRONT 20X8 REAR
truckin92pu is offline   Reply With Quote
