Airdeano,
A 4/6 is a nice "slammed" stance for most people and you can use some Air Lift helper bags like CKTA did on his 96 to keep the rear end level when you tow/haul stuff. Or, if youre looking to spend a little more money for lower, you can use 2" spindles, the Air Ride Technologies Cool Ride front bag kit , the KP parallel 4 link, an engine driven compressor like the Air Commander, 3/8" valves and line, and a couple 5 gallon tanks under the bed for storage. Since youre not concerned about laying you can get a notch from SuicideDoors.com and cut it down to fit under the bed, weld it in and then box the areas of the frame closest to the notch. You'll have a super strong, towable, reliable, easy to install bag setup that gets lower than most.
2003 Avalanche 2500
2002 Tahoe
1996 Silverado
