Old 11-20-2004, 12:59 AM   #51
PUSHROD
Member ID: 20903
Re: Rear End Ratio RPO Codes Here
I believe these codes are pretty much a standard across the board for GM for the most part they are located on the Service Parts Identification Label as stated in the glove box and you can reference the codes from a GM service manual usually they are listed in the General Information section in the front of the manual, also these manuals are what the techs actually use to fix your ride when you take your vehicle to a dealership I hope this helps. Thanks
