Thread
OBS 88-98 PST front poly bushing upgrade
12-19-2004, 01:44 PM
4
DjLunchbox
king rigger reppin CAF I
Status:
Offline
Member ID: 7624
Pics:
My Gallery
Re: OBS 88-98 PST front poly bushing upgrade
before we go any further, we need to clean the a-arms and get rid of all the gungy rubber left over inside the bushing ports.
i used a dremel with a wire wheel, and some goof off adhesive type remover. wear gloves if you don't like rubber stains on your hands:
sand and paint you arms now if you so desire, i used por-15 on all my stuff
be sure to clean the little metal pieces from the upper arms free of rubber too.
next, reinstall all the new bushings using the supplied lube that comes with the kit. this will stop any squeeks that WILL happen if you don't use it. lube everything that will move with a thin layer of it....
these are the uppers:
and the lowers:
DjLunchbox
View Public Profile
Send a private message to DjLunchbox
Send email to DjLunchbox
Find More Posts by DjLunchbox
