Originally Posted by 1 Clean 91'
In regards to calibrating the compass: When I installed mine, the directions simply stated to drive in a clock-wise circle about 3-5 times. That calibrated mine. Hope this helps out.
1 Clean 91'
Hey Kevin, Welcome aboard.
It's about time you got over here!
My original post were the instructions that came with the mirror. I would imaging that the zone should be set up in order to work properly. When I installed mine it was originally set at the wrong zone and it was off quite a bit.
Maybe you got lucky and yours came from a local truck with the zone already set.
lowdown
