Re: Rain leaking into cab
Here are the pic,s. I removed the fender and found that all i needed to remove was the small part of the driver side cowl to get to the leak. A little clear RTV sealed the leak now i need to find some molded vinyl flooring like the one that came in the work trucks to replace the wet stinky carpet that i removed. The screw driver shows where the void was located and the third picture shows the RTV applied. Also the void was only visible looking from the center of the truck looking to the outside.
