Old 10-08-2005, 03:02 PM   #115
CKTA
King of the Assclowns
CKTA's Avatar
Member ID: 66
Re: Home made air intake for '96-'99 Vortec trucks.
Originally Posted by tallone09
well i'm fixing give the mod at try let you know how it works out. one question where the roof clamp bolt to the way i understand you bolt it where the heater hose are bolted to on the fenderwell is that correct?
Correct...sort of. No bolts needed. What I did was take the plastic clamp off (it just clips on the inner fender) drilled out both holes a little bigger on the pipe hanger, lined the holes up w/ the inner fender then snapped the plastic hose holder back in place samwiching the pipe hanger in place.......nice and neat and no hardware needed.
Carlisle 2009 All Truck National info....
http://www.fullsizechevy.com/forums/...aug-7-9th.html
