Old 10-12-2005, 07:55 PM   #83
chevy_js
ryde ak
chevy_js's Avatar
Member ID: 34568
Re: Rear End Ratio RPO Codes Here
First of all, you can get your truck to shift into OD anywhere from 35 to 70 mph, it only depends on how heavy your foot is at the time. Second, that tells me nothing and wasn't my question. My question as i stated before was how fast in OD, meaning after you shift into OD, are you going once you speed up to 2k rpm. It should be ranging from 60 to 70, depending on gear ratio. I only wanted to check out other peoples gear ratios, Z71s & non-Z71, to see what speed the 3.42, 3.73, and 4.10 are @2k rpm. And therefore figure out what my gear ratio is, if it's actually as the code states, a GT5 (4.10). So anyone with some info about your halfton 4x4, it would be appreciated.
