Old 10-26-2005, 05:01 PM   #87
supersub1994
supersub1994's Avatar
Member ID: 33624
Re: D&)# Rear End!
Did you replace those gears yourself or have it done? Most falures are due to improper pinion shaft pre-load. If you go with a Richmond HD gearset, weld the axle tubes to the housing, use a C-clip eliminator kit, custom aloy axles, use a bearing support cover or billet bearing caps (these caps will need to be line bored), you will not have this proiblem again. I have a 7.5" 4.56 drag truck with a 525 HP & 580 ft/lb 406 and a 700-R4 tranny.
