Thread: Lift Specs
Old 11-03-2005, 06:33 AM   #55
hdmax
Mike
hdmax's Avatar
Member ID: 220
Re: Lift Specs
Maybe I overlooked it, the 2500HD, and 3500 has the same setup in 4x4 as it does in 4x2 trim. So you can add the 4x2`s to the list for the HD`s.
I took a 6-8" BDS lift, and a 2-3" lift (for the older style GM 1/2 ton truck upto 1998`s) and made it an 9-10" lift. (Set at 10") But I would not recommend anyone do this unless they know what they are doing.
Mike http://community.webshots.com/user/hdmax2002 Chevy 2500HD duramax Diesel, Allison 5 speed automatic transmission, Crew cab, Short bed, LS trim, Forest Green, 4x4, Limited slip, boost & EGT gauges, 35" tires 2.5" lift, EFILive=500+ rwhp
http://esnips.com/web/bigluke39-MySongs
