Old 11-07-2005, 04:34 PM   #64
DearJimmy
Premium Member #82
K1500
Member ID: 14628
Re: Rain leaking into cab
Originally Posted by Eric Guidry
This is all that needed to be removed to fix the leak i had. It was much easier to spot the leak without the fender and there was some leaves trapped in there that i removed also.
Be careful when removing these end pieces. There's a tab you'll see in the picture where his index finger is. I think you have to lift the side where the screw is and slide towards the fender. I pried it and the tab broke the part that it slides under. I'll just slap a little black caulk on it!!!!!!!!!!!!
******SEE PICTURE IN POST #29 ON PAGE 2******
