Thread: Post Your Setup
Old 11-10-2005, 07:25 PM   #71
bggrnchvy
bggrnchvy's Avatar
Member ID: 13799
Re: Post Your Setup
1997
Chevrolet
Silverado
4wd
38x14.50x16 Nitto Mud Grapplers
16x10 Cragar Soft 8's 4" BS
Front:3" ORU brackets, 4" lift Alcan springs(47" stretched to 52" with 3" added after the center pin), 6* tapered zero rate, 2" longer shackle for the longer springs.
Rear:4" ORD shackle flip, 3" lift Alcan spring, Zero rate.
Reunel and XD9000i(350lbs)
47.5" Front and 47" rear.
Inner fender cut ~8" up in the rear of the front, outer fender in the rear of the front cut and bent back a bit and bumper edge cut off for tire clearance.
No one is ever gone if they are always remembered.
JasonPayneMemorial
