Old 11-20-2005, 10:52 PM   #95
Bodydrop
Re: Advice on bagging a truck
I ran all air lift suspension with a modified rear setup, along with a york engine compressor, I had awsome luck with it the whole time i had it!! the only advice i could give to someone is spend the extra money run steel braided for you front section. its clean and safer i think. Plus i ran all Parker push lock hose and that stuff is awsome the fittings are exspensive but man is it worth it, i just can;t stand the plastic line that alot of company's use.
Bodydrop is offline   Reply With Quote
