Old 11-26-2005, 01:08 PM   #99
fabitup
Re: Advice on bagging a truck
I recently bought the following for my 98 extended cab short bed silverado...
KRZ tubular control arms, upper and lower
KP six link with cantilever setup
And connitech bags all the way around.
I plan on running these bags till I change them out for slams...I bought this setup all used from another member on this forum. I got a great deal on everything....Here are a few questions that I have now...
I need shocks for the front and rear...what should I use for the front and for the back. I also need to replace the ball joints on the control arms. I do not know if they are stock ball joints or not. Does any one know of a good urathane ball joints or any good stock replacements I could use????
As far as air management goes...I plan on doing this I believe....
Here is a link....
http://www.suicidedoors.com/Starter_Kit_1-2.php#
I am going to add another tank and compressor also down the road. But I am going to do this for now. I plan on mounting everything under the bed.
I also plan on running an 8-10 inch notch in case I go 22" inch wheels.....and 2 inch drop spindles....
More questions....
If I am running the KRZ arms, connitech bags, and 2 inch drop spindles will I need to cut the inner fenders out? If so what do other guys do to move the ABS and brake stuff over the driver side fender well? I want to be able to lay out on it. Also I am currently running stock 15 inch wheels with stock tires do you think I will have rubbing issues? I will buy wheels once the truck is down.
What offset do wheels need to be to tuck? and what lug pattern are the OBS trucks?
turns out I have more questions then originally thought.
Josh
fabitup is offline   Reply With Quote
