Old 02-02-2006, 01:59 PM   #4
Kruznlow69
Wuuuazuuup!!!
Kruznlow69's Avatar
Re: The York Thread.
great thread for a sticky.. just keep as posts regarding the yorks and setup/conversion to on board air.
mine is a custom bracket we made, uses a 210 and v-belt clutch, the tentioner pulley is jsut a regular idler pulley that is pushed down in a slot. i use the overdrive kilby combo pulley and top rotolock/tube-o fittings from on board air. i also swapped my 105 amp alt to the large case 140 amp which requires a new rear bracket (oe part for trucks with the 140 amp oe alt) to be installed ($5 from gm dealership)
here are some pics..
custom bracket
setup unmounted
setup installed
REBUILD THREAD Wreck Thread My StreetSource
"Lifes all bout making mistakes, It's how you learn from them that counts"
Kruznlow69 is offline   Reply With Quote
