Old 02-10-2006, 10:18 AM   #46
95Silverado
Truckless
95Silverado's Avatar
Member ID: 14669
So if I have a dual 4ohm subwoofer that will be wired parallel to give the amp a 2 ohm load, I would use 4ohm in the equation, correct?
So would it be: Voltage= sqrt(250wrms(rating of sub) x 4)
And do you get 31.3V for the answer as well?
Thanks in advance
