Old 02-21-2006, 01:01 PM   #21
DjLunchbox
king rigger reppin CAF I
DjLunchbox's Avatar
Member ID: 7624
Re: OBS 88-98 PST front poly bushing upgrade
Originally Posted by AirSchatz
So, what kinda advantage is there to doing this? Does this make for a smoother ride? Better handling?
it's better handling for sure, but you will tend to feel the bumps a little more. if you want smooth, install all rubber stock pieces, but they flex really bad
when cornering and i prefer the poly bushings. the poly doesn't brake down as fast as the rubber, helps in cornering and body roll, and chances are, your truck will need new bushings if it is a few years old anyhow, so why not go with the good stuff
