88-94 to 95-98 All Swap Info Compile
This is all the information that is available as of now compiled to make it easier for everyone to follow.
Included is:
Cluster Wiring
Power Door wiring MAN-POWER / POWER-POWER
Light Switch Wiring
To come:
A/C and Heater
Blower Motor
Power Mirrors
Power Seats
Overhead Console
This information is complements of Project 2005,SilveradoSS22s, and myself. I will update as more information arises and will make a complete '88-94 to 95-98 interior swap tutorial when the time comes including the power seat swap complete with pictures and diagrams.
Any corrections of suggestions please PM thanks.
ADDED: 88-94 to 95-98 Power locks and Doors
Manual to Power
Power to Power
Gauge Cluster Swap for Dash Swap
88-94 Function 95-98
A Alternater - 19
W Gas 16
R Temp 13
P Oil 15
T Tach 6
S Speed 14
N,G,Q Ground 31,34,4
F,O,U Fuse 22,7
B Anti Lock 27
C Check Engine 23
E Park Brake 28
J Low Coolant ??
L Left Turn 3
M High Beam 5
V Illumination 29
X Seatbelt 30
Z Right Turn 32
Light Control Swap for Dash Swap
88-94 95-98
Red \\ Red
White \\ White
Green \\ Green
Brown \\ Brown
Orange \\ Orange
Black \\ Black
Yellow \\ Yellow
Door Panel Swap 88-94 With Power
88-94 \\ 95-98
3 PIN HARNESS
Tan \\ Tan
Dark blue w/white stripe \\ Light blue
Red \\ Yellow
6 PIN HARNESS
Light blue \\ Light blue
Black w/red stripe \\ White
Orange w/black stripe \\ Orange
Grey \\ Grey
Tan \\ Tan
Black \\ Black
Door Panel Swap 88-94 Without Power
95-98
DRIVER SIDE \\ PASSEGNER SIDE \\ TO TRUCK HARNESS ( Under dash )
3 PIN HARNESS ( WINDOWS )
Tan \\ Tan
Light blue \\ Light Blue
Yellow \\ Yellow \\ POWER +12V Ignition (PINK)
6 PIN HARNESS ( LOCKS )
Light blue \\ Light Blue \\ POWER +12V Constant (RED/ORANGE)
White \\ White
Orange \\ Orange
Grey \\ Grey
Tan \\ Tan
Black \\ Black
This is still underway.
95-98 Steering Column Wiring Pins:
A1 - TCC/Stop Lamp Switch Output
A2 - Fused Ignition Output
A3 - GND
A5 - Right Turn Output
A6 - Left Turn Output
A11 - Horn Output
A12 - Cruise Control ON Switch Output
A13 - Fused Ignition Feed
A14 - Cruise Control Set Coast Switch Signal
A15 - Cruise Control Resume / Accel Switch Signal
A16 - GND
A17 - Brake Transmission Shift Interlock Solenoid Feed
B2 - GND
B3 - Key Reminder Feed
B4 - Key Reminder Out
C1 - Ignition Switch Output - OFF,RUN, CRANK
C2 - GND
C4 - Ignition Feed
C5 - Ignition Feed
D1 - Ignition Out - CRANK
D2 - Battery Feed
D5 - Battery Feed
D6 - Ignition Switch Output - ACCESSORY
E1 - Turn / Hazard Feed
E2 - Stop Lamp Feed
E3 - Wiper Motor High
E4 - Accessory Feed
E5 - Wiper Motor Pulse Wiper Signal
E6 - Right Stop / Turn Feed
E7 - Left Stop / Turn Feed
E8 - Battery Feed
E9 - Turn / Hazard Flasher Output
E11 - High Beam Feed
E12 - DRL Relay Output (Low Beam )
E13 - Headlamp Out
Add notes:
All parts from 88-98 are interchangable with one and other. This means that all parts in the 88-94 style interior WILL fit into the 95-98 interior and visa-versa.
Tech notes:
98 dash install: All three bolts on top and the top on bottom line up perfect. The a-pillars and kick panels also snap right into place.
95 GMC RCLB Z71 3/4 ton
6" Pro Comp Suspension, 3" Body Lift
35x15.5x15 TSL SX's
