Re: Glass interior started
Originally Posted by HARDEIGHT
Thanks for all the kind words.
DJ i can get it in and out from inside but its wayyyy eaiser to access everything with the glass out.
I took the glass out a while ago to put a roof skin on so its pretty much stayin out till the end. I have to do all new glass on this truck cuz it sat outside for 10 years and the sun burned all the black trim out that borders the glass. The most expensive glass are the 2 ext cab windows .1 is almost as much as a windshield .
Take care Dave
One thing DJ you will prob. have to pull the colum if you dont remove the windsheild.I'm taking mine out as soon as I get the dash mounted solid ,need it in now to get the proper clearance for the colum.
hmmm. i wonder if i can work off my stock dash and do the heavier glass work around where the stock guages are. you can cut the stock one to look like yours ,all one piece across...... ima have to go look at my spare one
that would be easier to mount and work with, support wise ...
