Old 03-19-2006, 09:28 PM   #77
496-TKO
formerly Phantom Dually
496-TKO's Avatar
Re: New Door Pods (Work Log)!
Originally Posted by DSZ71
Infinite baffle is made by running a driver in an enclosure thats just way too big for it, and its created when you deaden your door and seal it off, baically creating a box thats too large.
For example, you can run a 10" woofer on the rear shelf of a car, using the trunk (properly sealed of course) as the IB enclosure. although not all subs or drivers are suited for this type of enclosure, so make sure yours will be. Most midrange drivers are fine though, its the subs you need to be more picky about.
So would it be good to seal off everything on the door with Dynamat? Vents and all? I really am not getting no where near the midbass these speakers can put out. Thx
1992 Stepside 496 CID ladderbar rear suspension adjustable coilovers belltech springs in the front and djm spindles. See my gallery for progress pics!!
496-TKO is offline   Reply With Quote
