Old 03-20-2006, 01:24 PM   #58
97sierra454
97sierra454's Avatar
Member ID: 36350
Re: Power Mods for the 99-02 4.3 V6
Originally Posted by C15.1
comp cams makes aluminum roller rockers for the 4.3, they are especially narrow for the center bolt styled head
Crane does too, the only thing that sucked was to use their rockers, you had to buy all new studs to get rid of the stock rocker system where you bolt them down till the bolts are tight, you have to buy traditional studs so you can adjust their rockers. All in all it cost me close to $400. It did buy me some higher rpm breathing and a little better top end.
I also have had good luck using the MSD coils on these motors to make up for the lack of coil over plug like the 2nd gen vortec motors.
1997 Sierra 2500HD 4x4, 454, ECSB
1993 Sierra 2500LD 4x4, 6.2 Diesel, ECSB
2005 Blazer ZR2
1995 Camaro Z-28
1991 Olds Bravada L31 Vortec conversion
Various full-size Jeeps
