Old 04-11-2006, 05:50 AM   #78
karot
Member ID: 45515
Re: Rain leaking into cab
Hello, read through the forum and tried to tackle repair. Took off plastic cowling and plastic scuppers. Pulled back carpet on drivers side. Plugged drain hole with a piece of rubber and rag and dumped about a quart of water into the cowling box on the drivers side. It didnt take long for a stream of water to show on the inside. The only thing I could see that could leak inside was the seam going front to back.(It looks like an upside down gutter) Used air to blow water out and then cleaned area with laquer thinner and then rtv siliconed the seam. Next day put hose to it and it still leaks inside cab. Anybody have any more suggestions? I looked at every screw hole and even the bolts for the hood hinge, they all seem to just go to a flange and not penetrate the cab. Thanks .
