Old 04-13-2006, 09:59 PM   #25
Kruznlow69
Wuuuazuuup!!!
Kruznlow69's Avatar
Re: The York Thread.
Originally Posted by Low88
Here is a .doc on all the heat testing info you would want.
awesome info!!!!!!!!
continuously running for one hour and up to 243 degrees.. really not that bad..
was doin some research on some tranny oil coolers today and found one with fitting ends and handles 300psi working pressure.. thinking of running my york directly to it in front of the a/c condenser next to a actual used tranny cooler and then to my filter , press switch, and check valve. cooler shouldn't be too much $. for now i jsut ran 10ft of hydro hose out of the york, up front acrosse the a/c conenser and then back to the filter (behind my pass headlight where battery usually is.. need more time to finish..
REBUILD THREAD Wreck Thread My StreetSource
"Lifes all bout making mistakes, It's how you learn from them that counts"
Kruznlow69 is offline   Reply With Quote
