Old 04-16-2006, 09:24 PM   #36
Beyond Static©
Xcentric Customs
Beyond Static©'s Avatar
Re: OBS Stock Floor Body-Drop how-to....lay that rocker
Originally Posted by madramper
Is there any reason why you wouldn't weld the 2x4 to the top of the frame? Then you could cut the bottom off. Rather than drop the body, you would raise the frame.
Any thoughts?
then your front end suspension, tranny, and engine would hang too low, as well as needing a bigger notch out back to lay frame. You could Z the frame up front if you really wanted, as well as put a 3" larger notch out back. Thats how the 73-87's are done, but their frames only hang down 1" past the rocker, not 3" like the 88-98's
Beyond Static© is offline   Reply With Quote
