Re: OBS Stock Floor Body-Drop how-to....lay that rocker
Originally Posted by Beyond Static©
then your front end suspension, tranny, and engine would hang too low, as well as needing a bigger notch out back to lay frame. You could Z the frame up front if you really wanted, as well as put a 3" larger notch out back. Thats how the 73-87's are done, but their frames only hang down 1" past the rocker, not 3" like the 88-98's
I thought it sounded too easy! And my truck is a 95 Lightning. The frame is almost 4" below the rocker. I wanted to build a frame to ditch the Ibeams. I was going to do a Mustang II IFS up front and a T-bird IRS in the back. But its way out of my budget!
Thanks for the replies!
